Old 09-12-2005, 07:50 PM
Default My 6 year quest for a CX coded THM400 just ended
Hi everyone,
Recently, I posted a topic here about the special Turbo400
transmissions used in the 396/375hp cars, COPO and other
super cars, etc.. These were CX coded. Over the weekend,
my 6 year quest for one of these babies ended successfully.
My original CX went bye-bye a long time ago (before I owned
the car). I had been looking for another one it seems forever.
A few weeks ago, there was an eBay auction for a complete,
untouched L/78 engine out of a 69 Nova. The seller also
mentioned it came with an M40 transmission. Seems it was
removed in 1974 due to the gas crisis - remember that?
So, I contacted the seller to get all the particulars. You
know, casting numbers, dates, and the code on the THM400.
To my shock, I was told that the code was a CX. When I
came to ( passed-out ), I knew what I had to do. Much to
my dismay, the seller would not break the THM400 away from
the L/78 auction.
Also, after he found all of the casting number & date codes,
he did not update his auction. The auction did not meet
the reserve price set, so it ended. I contacted the seller,
and ended up buying it all. Mostly, because he still would
not split up the items.
So, I have a complete "JL" coded L/78 engine and the CX
coded THM400. All I wanted was the CX, so the L/78 will go
up for auction. The main reason for this post is that I
found a slight date issue that I would like to resolve.
This engine has a assembly code of T02??JL. The ?? denote
two numbers that cannot be read. I have looked very close.
The heads are late January dates, the exhaust manifolds are
mid February dates, the intake is an early January date and
the distributor is a late December (68) date. Also, the
water pump is an early January date as well. The odd thing
is that the 3955272 block is an H-13-8 date. Almost six
months before the assembly date of the engine.
What do you guys think about that? I have every confidence
that this engine is the "real deal". Any thoughts? Images
below:
Steve
Old 09-12-2005, 08:04 PM
Default Re: My 6 year quest for a CX coded THM400 just ended
I don't think the block is too early for that build date. In talking with jeff of Dated Components, 6 months is well within the timeframe - he has seen as much a 1 year gap to as little as 2 days.
Old 09-12-2005, 08:06 PM
mockingbird812's Avatar
Steve,
I resized the 1st picture for you - will do the others in a few. Nice motor. Good luck!:
Sam...
Old 09-12-2005, 08:08 PM
Looks like your pix are coming thru now. Were'nt the first time I looked at your listing.
Sam...
Old 09-12-2005, 08:14 PM
Chevy454 Chevy454 is offline
Did you happen to get the converter?
Old 09-12-2005, 09:23 PM
ANDY M's Avatar
ANDY M ANDY M is offline
I could use one of those CX M40s. Hope I get as lucky as you.
You GO
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 09-12-2005, 09:34 PM
Enoch Enoch is offline
Banned
Steve, from the picture that looks like the real deal. The block has been lightly decked and the month date #'s were not as deep as the others that's why you cant read them. But just at a quick glance that's the original stamp. I also have seen a few block casting and build dates stretch out that long, although they are few and far between.
Old 09-12-2005, 10:42 PM
TimG TimG is offline
Six months is well the within acceptable range. A wider spread is always expected for a high performance big block.
Here you have a solid lifter automatic, not many made. That four bolt block may have just sat in inventory for a long time waiting for assembly.
Old 09-12-2005, 11:14 PM
Wow. Looks like enough of the partial VIN is present to figure out the VIN of the car it came in. What cars were made at the W factory? Looks like 19W42?366.
Lynn
Old 09-12-2005, 11:21 PM
Allen Allen is offline
Lynn
Willow Run, Michigan plant = Nova!
Allen
