Old 09-10-2005, 11:39 PM
barkmmi barkmmi is offline
Default 14x7 or 14x6 Steel Disc Brake Rims
Looking to put steel rims back on my '67 Camaro. Converted to discs from drums so my original rims won't work. Love the "poverty" cap look though. Not too worried about dates or coding, just need a set of wheels that can clear the calipers and let me put the stock caps back on. Thanks!
Old 09-11-2005, 12:46 AM
Rat_Pack Rat_Pack is offline
Default Re: 14x7 or 14x6 Steel Disc Brake Rims
Here is the list of steel wheels you can use on your Camaro with disc brakes..............RatPack...................
Std steel wheel applications for disc brakes:
XF 14 x 6
68 Camaro all with disc brakes
68 Chevy II all SS and all with disc brakes
69 Camaro all with disc brakes except SS & COPO
69-70 Nova all with disc brakes except SS, and optional wheel on drum brakes in 69.
XT 14 x 7
69 Camaro SS & COPO with disc brakes
69 Nova SS with disc brakes
70 Nova SS & COPO with disc brakes
There is also another 14 x 7 steel wheel that will work and it is coded IF and was used in 1969 along with the XT wheel. I have also used the 70-up 14 x 7 steel wheel on the 67-68 disc brake cars and they fit. If you are not worried about numbers then I can help you with a set of those wheels just send me a private message as email is currently not working..............RatPack..........
Old 09-12-2005, 11:52 PM
bigchevydaddy bigchevydaddy is offline
JZ 14x7 rims closely match the XT and IF rims as well.
