Old 08-23-2005, 07:31 AM
Kacyz28 Kacyz28 is offline
Default 69 camaro
needs to go brand new AR TT IIs17x8 front 17x9 rear, new fuzion zri tires,globalwest upper control arms with solid bushings,new lower control arm solid bushings 1 1/4" hollow front sway bar,1" solid rear sway bar,ls1 front brakes,new rotors,lt1 rear brakes with new rotors on a 8.2 10 bolt,new flow tech lt headers,267 v8 with edlebrock 600cfm manual choke carb,edelbrock perfomer intake,th350 long shaft, b&m ratchet shifter,new gas tank and fuel sending unit,new wiring,all new light bulbs,competition engineering sfcs in trunk, the rear frame rails are solid,quick ratio streering box from a late 80s iroc z...parts not on the car but go along with is a disassembled 93 LT1, t56 that need some parts ,ford 9"that came out of a dirt track car,NIB CC 306,crane gold 1.6 roller tipped rockers....needs to go either trade or cash
