Old 08-12-2005, 11:08 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
Default Lug nuts on 1969 Nova SS wheels
Can someone please post a picture of an original lug nut fitted to a 69 Nova with SS wheels
Martin
Old 08-13-2005, 02:48 AM
Default Re: Lug nuts on 1969 Nova SS wheels
Does this help?
Old 08-13-2005, 04:17 AM
Yenko Paid Member
Thanks MR70..Those are the ones I have, however my front wheel has come loose because the nuts have worn through the wheel holes. I purchased some aftermarket ones last year. The shank was approx. 1/8 in shorter on those. May have been the cause. If I look in the Classic Industries catalog the lug nuts they show for 69 SS wheels do not look at all like the ones you our I have. I'll remove the wheel tomorrow but it looks like I might be looking for a new SS wheel if its too badly damaged.
Again thanks for posting the pic!
Martin
Old 08-13-2005, 05:15 AM
TDW TDW is offline
Martin...GM makes a lug nut for the SS wheels that has a larger taper where it meets the wheel. They are designed to be used when the factory hole has been enlarged from over tightning. I have a set and they seem to work fine. I can give you a part number if you are interested in them.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 08-13-2005, 07:22 PM
Yenko Paid Member
Tony,
Thanks for the tip...Went to Carquest this morning and found the nuts..They work great..Wheel is damaged slightly but this fixed my problem. Bought a set for each wheel.
Regards,
Martin
