Old 08-08-2005, 08:03 PM
rsatz28 rsatz28 is offline
Default Blown Head Gasket - How to Verify
How to determine a blown head gasket? Any visual signs?
Rob
69 <font color="orange">HO</font> Z-28
Old 08-08-2005, 08:33 PM
Default Re: Blown Head Gasket - How to Verify
Maybe some water in the oil. (milky)If it is leaking out you will see it on or around the motor. Overheating? Idling rough or missing?
Old 08-08-2005, 08:35 PM
DarrenX33's Avatar
How bout... What are the symptoms??
1969 Z28
1972 Corvette
Old 08-08-2005, 08:59 PM
I've left out the symptons that I am seeing so that I get some things to look at/compare.
Rob
Old 08-08-2005, 09:05 PM
427TJ's Avatar
427TJ 427TJ is offline
Steam coming out of the exhaust when engine's warm, water/coolant coming out exhaust pipe(s), exhaust has slight anti-freeze smell (if you use anti-freeze), frequent need to refill/top-off cooling system (cooling system checks okay--no leaks), milky oil, increasing oil quantity as coolant enters/fills crankcase, bad compression check on one or more cylinders, or a combination of any/all of the above.
Old 08-08-2005, 09:17 PM
It could be blown between the cylinder bores but not to a water hole. Run a compression test.
You could also pump up each cylinder with compressed air, using an adaptor in the spark plug hole, and look for bubbles in the radiator.
Old 08-09-2005, 06:48 PM
Thanks to the responses. Update. The symptoms were as follows:
1) The water temp seemed to run higher this summer than in the past. (I had pulled off the intake over the winter to detail the engine.) With very little "extra cooling" evident on the way home in the evening or night from a cruise.
2) This past Saturday I took a 1/2 hour round trip to get gas and the temperature slowly rose the whole time. By the time I got home the temp was @210 and rising.
3)Checked on Sunday afternoon when it was safe to take the rad cap off. Coolant level was aprox 3-4 in below the opening. Observed bubbles inside as the engine was running.
4) When I ran the engine up in RPM, the fluid level went down to about half.
5) Added some coolant, and as the tempurature approached 180, the fluid started to run out the overflow tube. (I know that water expands as the temp increases) Noticed very little movement of water through the radiator. I have an 180 deg t'stat and expected to see movement at 180 deg. Rad cap was still off. Put the cap on. Rad hoses full and could not squeeze rad hoses.
I found the problem last night , but will confirm tonight when I put things back together.
Anybody like to take a guess what the problem was?
Rob
Old 08-09-2005, 07:11 PM
Stuck thermostat
Jake is my grandson!!
Old 08-09-2005, 07:23 PM
Very close, but not exactly....
Rob
Bad sending unit? Radiator need to be re-cored? Water pump, bottom rad hose,Your imagination!!
