Old 08-01-2005, 05:49 AM
Default Correct Water Pump - 1970 L78?
Is the water pump casting number the same for 1970 L78 and LS6 motors?
What would be the correct water pump casting number for a January 1970 L78 Camaro?
Thanks in advance for your help, you guys have ALL the knowledge...
-SAm
Old 08-01-2005, 06:04 AM
Mr. T Mr. T is offline
Default Re: Correct Water Pump - 1970 L78?
3931065 casting # for your L78 Sam, including LS6 Chevelles. Late L78's and LS6's also used 3969811.
Tony
Old 08-01-2005, 06:17 AM
Thanks Tony,
Was the 3969811 only used on 1971 models?
Old 08-01-2005, 06:22 AM
I believe 3969811 was used from late 1970-72.
Tony
Old 08-01-2005, 06:37 AM
DOH!
Tony,
Thanks for the info. I better find a 3931065 with a date code of late Dec 1969.
-Sam
Old 08-01-2005, 06:56 AM
The 69 SS396 Camaros also received the 3931065 water pump, which carried over to early built L78's.
Tony
Old 08-01-2005, 07:01 AM
Thanks, saw this Dec 30 1968 pump on eBay..item number 7989634859
Old 08-01-2005, 07:07 AM
One year later and you would be in business!
Tony
Old 08-01-2005, 07:23 AM
By the way Sam, what is the build date of your car, and the assembly date of the L78? I will keep my eyes open for you.
Tony
Old 08-01-2005, 07:25 AM
Sam
The 1970 L-78 & LS-6 used the #811 Waterpump regardless of Car it was installed in,not the #065.
#065 was used for engines before the 1970 release,Maybe,Maybe Aug.-Sept. 69 built cars got them,at least from my findings.
Your not going to find an #065 dated Dec.69,they stopped making them around May 69??
I have an #811 here I took off an LS-6,dated L 69.
