Old 07-27-2005, 06:56 AM
DSYenko DSYenko is offline
Default Muffler question
Im sure it's been hashed over in the past but i need to buy a pair of 2.5 mufflers to run on my 400-450 horse 454 that i just installed in my 76 Chevelle.What are some good choices for free flowing mufflers.Some noise if fine as it's kinda my Hot Rod for around town but noise is not a necessity but permitted if it comes with the free flow. Thanks
EX 81 YENKO TURBO Z owner
Old 07-27-2005, 07:11 AM
Chevy454 Chevy454 is offline
Default Re: Muffler question
Go with the Dynomax turbos...the guys over at Team Chevelle have the numbers memorized, but I tried a bunch of mufflers on one of my '69s, and those won hands down...plus, there is dyno proof they make more power as well as sounding better...and if you wanna get hi-tech, add an x-pipe...
Old 07-27-2005, 07:29 AM
MosportGreen66's Avatar
I know a guy who has a 1981 Z28. Its a 383/powerglide with a tall rear. His Camaro runs 12.80s all day long. He tested the Flowmaster American Thunder and the Dynomax Mufflers on the track... ready for this... his Camaro ran 2 tenths of second faster with the Dynomax units.
Don't make the same mistake I did... buy Dynomax
Old 07-27-2005, 07:32 AM
There's a test somewhere here on the net where some well known Poncho racers tested a slew of exhaust setups on a Pontiac bracket wagon...I can't find the link (yet), but a Dynomax w/x-pipe combo was just a shade behind the open header combo...
EDIT: here's the test...a good read for everyone: exhaust shootout
Old 07-27-2005, 09:17 AM
Dynomax it is! Thanks a lot!
Old 08-12-2005, 08:47 AM
I have fallen a little farther behind than i expected in getting the engine fired up but am finally ready to order the Dyno Max's.How long are the mufflers you reccomend? They make 14's 16's 17's and 20's.The part number for the 20 incher is the one listed in one of the test you linked to but 20 sounds pretty darn long but maybe thats why they flow so well. Hate to get the big ones if the shorter ones flow as well ,just checking to see what you have .Thanks
Old 08-12-2005, 09:41 AM
musclcar musclcar is offline
i just installed 3" exhaust and dr. gas X-pipe on my 72 camaro with flowmaster delta force 40 series race mufflers part# 94330419. the exhaust note is awesome and i noticed the engine is more responsive.there is some interior resonance but it's liveable and at WOT the sound is unbelievable.the muffler case is 13" long and 4" thick.
72 camaro ss 350 sbc 425hp old school day 2 build-up
Old 08-12-2005, 09:55 AM
Rat_Pack Rat_Pack is offline
DSYenko,
I used the Dynomax mufflers on my 76 Laguna and I believe they were the 14" ones #17734 with the 2.5" offset inlets and outlets. Check with your exhaust shop as to which ones fit the underside of your car correctly as far as case length but all dual exhaust 66-77 Chevelles have offset inlets & outlets. Most of the exhaust shops here locally keep the Dynomax mufflers in stock or can have them the next day. I can check with the guy that I sold the car to and have him measure them to make sure they were not the 20" mufflers. One thing I did have to do is install a transmission crossmember from a 73 Chevelle SS, so I could run a true dual system with equal length headpipes, as that was the last year for a true dual exhaust in the GM A-body platform. 1974-77 models all had catalytic converters and the exhaust was split after the converter and the crossmember only has clearance on the passenger side for the pipes. Be sure to run a cross-over pipe to equalize the pressure of both sides of the engine, especially if you are using your original trans crossmember...........RatPack..............
Old 08-12-2005, 05:49 PM
I already have the 73 duel exhaust crossmember installed.Im just about ready to fire it up and break it in on a old set of manifolds with short down pipes.Then install my nice manifolds and off to the muffler shop next week. Thanks for the help
Old 08-12-2005, 05:56 PM
I've never heard of problems with the 20s...and I'm tellin' ya, they sound sooo goood! Even though I'm stuck with a Flowmaster on our Camaro, I'm not a real fan of the Flowmaster sound...on my L78 Chevelle I had a like new set of Flowmasters and promptly discarded them for the Dynomax big cases, and never looked back...but, different strokes for different folks!
