Old 07-27-2005, 03:40 AM
Belair62 Belair62 is offline
Default Muscl car's Day 2 2nd Gen Camaro
This is my daily driver a 1972 camaro ss that has been built to 70's
performance standards or day2 old school theme.
Engine : 350 sbc
425hp /490 ft lbs torque / 11.5:1 compression / ported-polished #462
cyl heads 2.02-1.94 valves / GM #3927140 mechanical solid lifter cam
257/269 dur. 493/512 lift 112 LSA 4200-7000rpm / pete jackson "noisy"
gear drive / early 70's edelbrock TR1-X tunnel ram (2) 70's correct
holley 600 vacuum secondary carbs / older mallory unilite mechanical
distributor and accel super coil / baldwin motion valve covers / flex a
lite "green" fiberglass flex fan / hedman long tube headers w/ 3" pipe
to dynomax super turbos terminated at the axle.
Transmission: turbo 350 with shift kit and B&M 3000 stall converter.
Rear axle: gm 10 bolt with 4.10 gears and welded up spider gears or
"lincoln locker".
Interior: old school day2 theme with old B&M quick clik shifter no
center console /sun blue line gauges and tachometer/ rear seat removed.
Other items : 15x4 ansen sprint mags and 6/50-15 tires /15x8 chevy rally
rims w/ 295/60-15 tires / lift off fiberglass L88 hood with 4 pins.
Future add-on & parts: 15x10 ansen sprint mags with N50-15 mickey
thompson indy profile tires / large GM grump lump hood scoop to be
bonded onto the L88 hood / lakewood traction bars / also have besides
the tunnel ram a edelbrock TM-1 and a edelbrock scorpion usually run a
holley 850 DP
Performance: 12.42 @ 107mph
History: I’m the second owner of the camaro and it's a norwood car that
was built the day before the big work strike there in 72.
I really enjoy driving my camaro around I’m constantly getting thumbs up
or nice comments about my camaro. I’ve won 8 trophies in 2 years at
local car shows.
chuck
(aka) muscl car
72 camaro ss 350sbc 425hp/356 hp @ rear wheels baldwin motion
restification in progress
