Old 07-23-2005, 06:52 PM
PPPJJJFFF PPPJJJFFF is offline
Default Is it an LS6?
Looking at a Chevelle with partial buildsheet.
Has ZL2 SPC DUCT HOOD, Z15 SS 454 CONVER
Air-cleaner DG
Tire Press Label BC
Tach 983
Can't make out much more.... Patrick
Old 07-23-2005, 06:59 PM
Default Re: Is it an LS6?
Nothing you listed is LS-6 specific.
Except that Tach number...#983 is indeed a 6500 redline tach.
Also I see it is a Baltimore,Md. Plant Chevelle.
Tell us more when you can.
Old 07-23-2005, 07:08 PM
V Belt Groove 3 ##
LP PADS 052
Engine Tune Label (Can only read DT)
Box 40 TCS-3
Air Pulley DA
Box 75 XU XF
Box 76 NHHD
Box 92 IRF -
BOX 106 f70x14-2e2-bb-ltr
bOX 59 929
Box 58 926--
Thats all I can read!!! Thanks, Patrick
Old 07-23-2005, 07:12 PM
I see:
Deepgroove Smog Pulley belt *
A white Interior
AC #727 Early Short Fuel Pump
TCS-Transmission Control Spark
Deepgroove Smog Pump Pulley *
Boxed rear lower control arms
M-22 Transmission *
*LS-6 Material on a 454 labeled Chevelle.
Old 07-23-2005, 07:24 PM
Wouldn't that DA smog pulley be a deep groove and confirm it as a LS6 since it is a 454 car ?
Old 07-23-2005, 08:39 PM
Yes..That "DA" Pulley & the Longer "YE" Fan Smog belt as well.
Correction on the statement I made about the M-22 trans.,it was also available on the LS-5 too,not just LS-6 ONLY.
But Patricks codes show this is a 1970 LS-6 Chevelle to me.
Old 07-24-2005, 11:35 PM
I went and looked at the car again today!! Here is some more information.
Body by Fisher Tag
ST70 13637 B833755 BDY
Tr 756 58 58 PNT
2A B D 0100
Hurst Shifter looks original to me. White knob R 1 3
2 4
Supposably a 66 or 67 427/425hp motor.
On the front of the block I.D. Pad reads TI 230 ID
Intake has a snow flake type casting on it.
Question Rick? You noted above White interior. How did you determine that. Has a black interior now. Looks like a 41,000 mile car without original engine and transmission. Comes with engine I described above, with closed chamber heads. Didn't get casting #'s. Any more opinions. Has a partial buid sheet found in the car. the last 4 digits of the vin # are the only ones I can see on the buid sheet. Its been torn in half. Vin# is 136370B14----. Thanks, Patrick
Old 07-25-2005, 05:54 AM
Cowl tag sounds proper.
Autumn Gold paint is nice.
Get a casting date from that block,to determine if 1966-67,or 68.
Sorry about the Interior translation.
LP Pad #052 translates to a Black Dash Pad,which both Black & White interiors used.
I have a chart showing the interior color codes from all the factories and didn't see the shared code.
Can you make out anymore of the last of the VIN#?
I have two LS-6 sheets that come close to yours in that time frame that probably were built the same day.
Old 07-25-2005, 08:02 AM
mmcporter's Avatar
mmcporter mmcporter is offline
Send a message via AIM to mmcporter
Thanks, Patrick
I'm not sure if you know this, but the LS6 originally would have come with a Muncie shifter, not a Hurst. The Hurst may have been installed by the original owner on "day 2", but it's not original. My LS6 has a Hurst shifter with an original chrome ball, but it's an aftermarket install.
Old 07-25-2005, 06:56 PM
I've sent you a PM with the Vin#. Patrick
