Old 07-19-2005, 11:53 PM
427TJ's Avatar
427TJ 427TJ is offline
Default Camaro ignition harness
Just installed a Factory Fit ignition harness on my '67 Camaro. There's a bracket mounted on the harness just above the two starter solenoid wires and it allows that part of the harness to be bolted/secured to the engine and away from the right-side exhaust manifold.
Which bolt should I back-out and run through this bracket? Just the upper-right tranny mount bolt? (396/Th-400)
Gracias in advance!
