Old 07-12-2005, 07:33 PM
SamLBInj SamLBInj is offline
Default Help with 69 camaro SS L78
Ok heres the deal,02B car Motor is a correct CE block with all the right stuff except alt. Rear is 331 posi and correct numbers, trans is 69 M20 from an april car. Tach is 5700 yellow-6k red-7K, has single fuel line. Looks like underside of car has no undercoating and also new gas tank and shocks. New wiring harness and some small maintanence things due due age..If you guys could check this out and give me your opinions and what you think its worth with this info let me know...No build sheets were found, seats, gas tanks, ect...Some odd oictures show up first?
http://cgi.ebay.com/ebaymotors/ws/eBayIS...=ADME:B:EF:US:1
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
Old 07-12-2005, 07:47 PM
firstgenaddict's Avatar
Default Re: Help with 69 camaro SS L78
That looks like 427 King's old Camaro.
Some people here may know the car.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 07-13-2005, 06:47 AM
That hockeystick is awfully thick. Hopefully it's just a stick on and can be easily corrected. Funny, you never see a hockeystick stripe that's too thin.
Old 07-13-2005, 08:35 AM
Compare to my cars original paint stripe.
Paul
69 Camaro SS L78
Old 07-13-2005, 09:07 AM
Thanks, Ive been staring at them thinking the same thing...I think I may pass on this car at this point, just too many small and maybe bigger issues...
Sam
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
Old 07-13-2005, 09:21 AM
here is a restored one
http://www.hemmings.com/index.cfm/fu...ail/id/2213052
Heres an original fatter one?
http://www.hemmings.com/index.cfm/fu...ail/id/2213220
What is correct for these stripes?
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
Old 07-13-2005, 09:29 AM
Snikeys, look at this one..
http://www.hemmings.com/index.cfm/fu...icle_id/221407
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
Old 07-13-2005, 09:30 AM
camarojoe's Avatar
Both cars you linked appear correct... As does the blue car in the above post... Black stripes have a tendency to appear "thinner" than white, its an optical illusion because the white is bolder against the body color. Compare any of those 3 cars against the orange one inthe first post and you should easily be able to see the difference... the orange one has a WAY thick stripe. Btw...Original stripes are painted on the fender, and a decal on the door... this was due to the body being painted separately from the front end.
Joe Barr
Old 07-13-2005, 09:32 AM
camarojoe's Avatar
That one has a "way too fat" stripe on it too...personally, i like the fathom green one the best of the 4 you have posted thusfar...just need to ditch the polyglases for a set of wide treads and you'd be in business...
Joe Barr
Old 07-13-2005, 10:01 AM
Heres another huge one, somebody must be selling these kits.
http://www.hemmings.com/index.cfm/fu...ail/id/2210790
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
