Old 07-05-2005, 08:19 AM
NOSLO6 NOSLO6 is offline
Default 9-Sec 1993 Camaro Pace Car
FS: 1993 Supercharged Camaro Z28 - Indy Pace Car edition. Stellar looking and rare car, built to run with a best of 9.68@138. mph on 93 Octane. Very clean car, always garaged. Featured in June 1998 Issue of Hot Rod magazine.
Engine -
383 CI
Lunati 3.75" Crank
Oliver 6" Rods
CP Racing Pistons (Custom Spec)
Aluminum heads Ported and Polished with 2.02/1.60 Valves
Port Matched Intake
Erson Blower Cam
BBK Edelbrock Throttle Body
Hooker Super Comp Long Tube Headers
Vortech T-Trim Supercharger ~20 lbs. Cogged Pulleys
Spearco Water to Air Aftercooler (Chiller Box located in hatch well)
Meziere Electric Water Pump
Accel DFI
Vortech/MSD Timing
95+ Optispark Conversion
Custom Dual 3" Exhaust
Borla Mufflers
Approximately 1000 miles on full motor rebuild
Trans/Rearend -
J.W. Performance TH400 Transmission
J.W. Performance UltraBell
Cheetah Turbo Action Shifter
Ford 9-inch Rearend W/ 3.50 GEARS and Disc Brakes
Suspension/Wheels -
AVO 12-Way Adjustable Front Coil Overs
QA1 12-Way Adjustable Rear Shocks
Modified Southside Liftbars
Airbag (RR)
Weld Ultralights - 15x6 F, 15x10 R
Brand New M/T Drag Radials 325/50/15
Misc -
Line Lock
Rollcage W/ Removable Drivers Side Swing Out
New RCI 5 PT Harness w. Quick Release Knob
Auto Meter Monster Tach W/ Memory Recall and Shift Light and Boost Gauge
Custom Hood
Methanol Injection Kit
Original hood and wheels will come with the car.
Asking $19,500 O.B.O. Ask For Dave 630-627-3192
Pics of car can be seen at www.tamrazs.com/pacecamaro/
Old 07-05-2005, 09:40 AM
Default Re: 9-Sec 1993 Camaro Pace Car
Welcome to the site..Cool car.
Old 07-05-2005, 04:02 PM
supercomp 8.90 supercomp 8.90 is offline
did you get this car from fl.? it looks like a friend of mines old car his name is george. if it is the same car it is very well built!! i seen it make alot of 9-sec passes,then he would drive it home!!!
Old 07-05-2005, 05:09 PM
Dave,
It says on the door plaque that this is pace car #439...built for George A. Welter.
SO if that's your friends name then it was his car!
Old 07-06-2005, 02:00 AM
yes that is his name!!! he owns a zippy lube right around the corner from my shop. he always has a toy or two.
Old 07-06-2005, 03:27 AM
70 copo 70 copo is offline
Great car with "HOT ROD" history. It would cost big $$$ to built it today. Good deal for someone.
Phil
Old 07-06-2005, 04:31 AM
Jeff H Jeff H is offline
And I thought I was the only one crazy enough to put a supercharger on a 93 Indy Pace Car! I remember seeing this car for sale a couple of years ago after I sold my 93. This car looks like a sweet deal for some serious performance and it still looks great!
Old 07-07-2005, 06:33 AM
Thanks to all who have inquired. Many have asked how hot does it run? Between 165-172 degrees.
Performance: 1/8 mile 6.21 @ 114mph on drag radial w/ 93octane.
Car does not have a trans brake.
Leaving from dead idle this car has a best 60ft of 1.39
Old 07-08-2005, 07:39 AM
Many have asked for the HP and Torque #'s
617.4 rear wheel HP
771.0 rear wheel torque
93 Octane
