Old 06-24-2005, 09:54 PM
Marina66SS Marina66SS is offline
Default Help on '67 Camaro VIN
I researched my VIN and trim tag last night for a guy who was interested in a car. The trim tag varifies what you can see on the car, White, Red Standard bucket interior, 4-sp, V8, RS/SS-350, deluxe appearence group. But what I wrote down the VIN it start 12337 which is for a 6-cylinder coupe. What's the deal? I don't see any tampering with either tag.
Jason Godsil
www.Exotica-Motorsports.com
Old 06-24-2005, 10:08 PM
Mr. T Mr. T is offline
Default Re: Help on '67 Camaro VIN
How about a picture of the cowltag? Vin numbers usually never lie, and yes that is a 6 cylinder VIN.
Tony
Old 06-24-2005, 10:12 PM
I do have a picture of it and I will post it later. The only problem with someone faking a trim tag would be that you would have to find an RS/SS-350 trim tag for a white/red 4-sp car, because that is definately what the car was from the factory. Then someone would have to buy all the hide away headlight set-up, put a 12 bolt in the rear etc.
Jason Godsil
Old 06-24-2005, 10:36 PM
JChlupsa JChlupsa is offline
Whats the VIN and Trim Tag data. Esp the Build date from the Trim Tag. Like MrT states, VIN is problely correct. Double check the Partial VIN looking through the Passenger side Cowl Vent. it should be something like 17Nxxxxxx or 17Lxxxxxx with the N/L being the assembly plant for your car and the x's being the last 6 of your VIN Plate on the car.
http://www.camaros.org/cowlvin.jpg
If its hard to see the Cowl Panel is not all the hard to remove and replace.
Old 06-24-2005, 10:48 PM
I had all this info written down last night so I do remember some of it. I remember the trim tag build week as 025, Feb. 5th week. Norwood. The cowl is off so I will see if I can find the VIN there.
Jason Godsil
Old 06-24-2005, 11:44 PM
Jeff H Jeff H is offline
Sounds like you're looking at the body number on the trim tag, not the VIN number on the door. You would need to give us the information from both the VIN tag and the trim tag to determine if it sounds fishy or not. A picture of the trim tag is helpful as well. If the trim tag is held on with screws, that's not a good sign. It could be that somebody swapped the driver's door from another car and it was a 6 cyl car. What is the VIN on the title?
Old 06-25-2005, 02:25 AM
The VIN is on the post not the door.
Jake is my grandson!!
Old 06-25-2005, 04:23 AM
So here is the info;
VIN 123377N138511
Trim tag
02E D
67-12437 NOR 84206 Body
741-Z C-C Paint
2LG 3L
4P 5B
The hidden ID number under the cowl is 7N184434
Are some of these numbers supposed to match?
How do I attached a picture of the trim tag?
Jason Godsil
Old 06-25-2005, 04:26 AM
Email the trim tag picture to me, I'll post it for you Jason.
Tony
Old 06-25-2005, 04:44 AM
I see one important thing wrong so far. The last six
digits on the hidden partial Vin# under the cowl, should match the last six digits on the Vin#, located on the post. In this case, they don't. Let's take a look at the cowltag, and go from there.
What's the partial Vin# on the engine?
Tony
