Old 06-07-2005, 07:48 AM
DSYenko DSYenko is offline
Default Ideal humidity for car storage?
Dont know if this has been discussed but what is a range or a ideal percentage to set the dehumidifier at in my car storage building.Thanks in advance
EX 81 YENKO TURBO Z owner
Old 06-07-2005, 08:22 AM
LVCamaro LVCamaro is offline
Default Re: Ideal humidity for car storage?
The average relative humidity [ARH] in Las Vegas is 39% in the morning and 21% in the afternoon [Phoenix/Tucson is 52%/25%]. Several major airlines store their excess and out of service airplanes here and Phoenix/Tucson because of the ideal ARH, so I concluded that a constant humidity of 30% would work well in my shop. No problems with surface corrosion so far, after 25 years.
SS
Old 06-07-2005, 08:36 AM
Belair62 Belair62 is offline
Have you looked in the mirror lately LV ? Looks a little corroded to me,
Old 06-07-2005, 08:41 AM
ARH in Chicago is over 70%, so I'd go check under the tarps at Bulaw's car shop for the rewards of that smartass remark
Old 06-07-2005, 09:21 AM
I have...its all been there so long it never had a chance to rust !!! Mark on the other hand...well he is rusting pretty good..
Old 06-07-2005, 02:24 PM
70 copo 70 copo is offline
Car Capsule works well non HVAC storage areas. My small 3 bay garage is climate controlled. Keep your area at positive pressure at all times and you will be ok. Air movement is the key. Kevin Hand has fans running on his cars all the time at his place.
Phil
Old 06-07-2005, 08:39 PM
camaromb camaromb is offline
Bob,
No rust problems here... just continued greying!!!
Mark
Old 06-07-2005, 08:46 PM
You look a bit rusty to me Mark !
Old 06-07-2005, 08:51 PM
SamLBInj SamLBInj is offline
Better rusty than Crusty
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
Old 06-08-2005, 08:02 AM
That helps a lot,,thanks for the info i appreciate it.
