Old 05-31-2005, 06:04 AM
pacecar pacecar is offline
Default 14 " rally wheel decode help needed
Found this in a wrecking yard , rust and dirty but there are some codes by the air stem....????
To the left of the stem -- K - 19 - 2
To the right ( not clear ) 13 + 8 or B ( not clear)
on the 8 or B .
I don,t need it but I wasn,t going to walk away for 30 bucks.
thanks Pacecar
Old 06-01-2005, 05:03 AM
Default Re: 14 " rally wheel decode help needed
I am assumeing that maybe I have entered some wrong codes or some thing ... can any 1 help ??
thank you pacecar
Old 06-01-2005, 05:21 AM
427TJ's Avatar
427TJ 427TJ is offline
Is there a two-letter code on the other side of the stem hole? That's the application code.
Old 06-01-2005, 05:34 AM
I entered the code wrong ,sorry for the confusion.
on the left of the stem - K -1 - 9 2
on the right side of the stem - 13 + B ( or 8 )
hope this helps. pacecar
Old 06-01-2005, 05:59 AM
nova7579's Avatar
nova7579 nova7579 is offline
If the wheel is a 14X6, it is probably an "XB" code wheel (from the information you have posted). I think that fits 68 and 69 Nova and Chevelle with disc brakes.
Brian
Old 06-01-2005, 07:43 AM
rpoz11's Avatar
rpoz11 rpoz11 is offline
Yenko Premier Member
I just bought a 14X6 that is stamped XE....
Chavez Ravine
Old 06-01-2005, 10:09 AM
427TJ's Avatar
XE denotes a base (non-SS) '68-'69 Chevelle with discs.
Old 06-01-2005, 05:30 PM
Rick H Rick H is offline
Steve,
I believe the rally wheel is a 1969 (K-1-9) built February (2) 13th (13).
On Rally Wheels date codes, the month code is usually on one side of the stem hole after the manufacture and year code and the day code is on the other.
Always read from where the K-?-? starts and it gets easy. 1969, February 13.
Hope that helps.
Rick H.
