Old 05-18-2005, 05:54 PM
55chevy 55chevy is offline
Send a message via ICQ to 55chevy Send a message via AIM to 55chevy Send a message via Yahoo to 55chevy
Default LOW OIL PRESSURE
Here's my delima... I just got done rebuilding the engine in my Nova and drove it to work today for the first time. It runs good. Oil pressure: It has around 60lbs at startup.. after warm it carries around 40-45lbs all the time (while driving) but when I come to a stop and it idles in gear it quickly drops to 10lbs or less.. if I hold it at around 1100rpm it'll hold around 20lbs but soon as I let it go back to idle it drops back down. ... what is WRONG???? and how long can I expect this engine to last doing this??? I'm out of money AND patience with this thing... ...........help
https://t.me/pump_upp
Old 05-18-2005, 06:14 PM
camarojoe's Avatar
Default Re: LOW OIL PRESSURE
I have always heard that as long as you have at least 10 psi per 1000 rpms, you have sufficient oil pressure.
Joe Barr
Old 05-18-2005, 06:28 PM
This engine just seems to be carrying pressure differently than all the other SBCs I've had.. This being the only one I've completly rebuilt myself (so far) I thought maybe I missed something somewhere.. (internal leak??..blow by?? something??).. The pressure goes up and down quickly with the rpms. .. Or am I just paranoid with my own work?
Old 05-18-2005, 07:16 PM
Pantera Pantera is offline
I.m betting on a weak oil pressure by-pass spring it the oil pump.
Pantera
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 05-18-2005, 07:22 PM
Did you install a new high volume oil pump, or the standard one?
Old 05-18-2005, 07:32 PM
budnate's Avatar
budnate budnate is offline
sounds like a bad or wrong application oil pump, I accidently stuck a BB oil pump on a SB once as a kid and it did about the same thing, was told by the parts guy it was pumping everything up ontop and starving the pickup... sorry Ed probably the last thing you want to do is deal with getting at the pump for a look at it.
Bud.
It's a new Melling pump.. I'm pretty sure it's just the stock replacement.
Old 05-18-2005, 07:35 PM
Mr. T Mr. T is offline
On all the SBC engines I have rebuilt in the past, there has only been one time that I witnessed sparatic oil pressures at different rpm's. It was an easy fix, and believe it or not, the oil pressure sending unit was faulty. I installed a new one, and the oil pressure at idle increased by 10 psi.
Tony
Old 05-18-2005, 08:12 PM
Think I should try a better oil pressure guage first?
I got the high dollar $9.99 Harbor Frieght triple guage package special in use at the moment...
Old 05-18-2005, 08:31 PM
Come by and I will loan you a SW gauge. It still does not sound like a gauge problem but you just never know. Like I told you in the email this morning to check it out first.
Pantera
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
