Old 04-16-2005, 01:47 AM
P.J. P.J. is offline
Default 1970 chevelle ls6 L78
In my investigation of which many members sent in pics of their accelerator brackets for the Ls6 L78 (thanks)this is what I found out.In 1969 when the chevelles were being built the 3972619 bracket was being installed on L78 cars. all of the brackets that I have found for L78 are shown in the pic.
The one on the right.
The other two brackets are all from LS6 cars. All the cars LS6 L78 were origional cars documented. There is a differnce in the brackets as the one on the right is made from a completely differnt die than the Ls6 bracket (see the tab area)of the l78 bracket.
We found 12 examples of the Ls6 brackets and 4 of the L78.
It would seem to me that it is more likely than not that all l78 brackets were different than the Ls6 cars. "Sharing information is a good thing".
suprss70
Attachments - The Supercar Registry 134787-2brackets.jpg 134786-3brackets.jpg
Old 04-16-2005, 01:49 AM
Default Re: 1970 chevelle ls6 L78
another pic of the LS6 brackets.
Both these brackets are made form the same die
If you turn them over the die left a machineing mark on both of the exactly the same.The stamps are different because the stamp punch was put in upside down when the die was sharpened and then reinstalled.You can also see the differerent dept of the stamps.Thats because when the die was sharpened the number punch was ground so that it sat in the die higher than its origional setting by about therefore
striking the bracket a little lighter.
suprss70
Old 04-16-2005, 03:22 AM
Brackets pics were donated by Rick LS6 Black 4speed
suprss70
