Old 04-04-2005, 12:30 AM
Default Converting non-SMOG to SMOG manifolds
Hi everyone.
I want to start off with a comment about the following post.
I have been criticized for posting a topic here as well as
on other forums in the past. I do this because I am trying
to reach as many knowledgeable people as I possibly can. If
my "double posting" offends anyone, please let me know.
Do any members here have any experience with getting non-SMOG exhaust manifolds
drilled & tapped ( properly ) to use with factory SMOG equipment? I have been
hunting the proper dated manifolds for quite some time now. I did find correct
dated non-SMOG manifolds ( which I bought as a backup ). Now, I am faced with
the prospect of getting these manifolds drilled & tapped for the SMOG ports.
I can certainly contact machine shops to do this, but centerline dimensions are
fairly important I would think. Furthermore, the configuration of the actual
ports are also important. I only have one shot at this, so perfection is the
order of the day. To that end, does anyone have a recommendation for a shop
that has done this type of work before? I don't want to learn the hard way. Also, I have been given conflicting
information on the actual tap size used for the SMOG ports.
What is the correct tap to use?
I would prefer to work with a shop that has this experience under their belt.
Steve
Old 04-04-2005, 03:04 AM
Default Re: Converting non-SMOG to SMOG manifolds
Sounds like it should be possible with a good machine shop, and a set of smog manifolds and tubes for a pattern. I'll bet GM drilled and tapped them after they were cast. I will ask around tomorrow if any of my local boys know someone who can do this. If there is, I also need a set done!
wilma
Old 04-04-2005, 03:07 AM
TDW TDW is offline
Steve...I would contact someone like Jerry MacNeish or Bill Hodel. They do a lot of smog system work. They should be able to help, or even do the job for you. Good luck.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-04-2005, 03:44 AM
Great idea! Anyone got a number or email address for
Bill Hodel?
Steve
Old 04-04-2005, 03:51 AM
TDW TDW is offline
330 832 0781..according to his ad in Hemmings.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 04-04-2005, 04:38 AM
Thanks Tony.
Steve
Old 04-04-2005, 11:34 AM
Musclecarkid Musclecarkid is offline
I just recently saw a pair of non-smog that were converted to smog manifolds. This guy does them in a fixture in a CNC machine. You can not tell when there done. Looks like the factory did it. Takes at least 4 different tools to do it correctly. PM me if you want him to do yours. Guaranteed perfect.
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 04-05-2005, 02:30 AM
Kevin,
I sent you a PM on this subject, I hope you got it.
Steve
Old 04-05-2005, 04:49 PM
Steve Shauger's Avatar
Administrator
I know Chris White provides this service as well.
www.vintagecertification.com
Old 04-06-2005, 02:05 PM
Steve, I will get in touch with you via email.Thanks, Kevin
Kevin
