Old 03-30-2005, 03:37 PM
Default Spring Tag Questions??
Where did GM usually put the front and rear spring P/N tags? I just restored the rear leafs and am starting on the front springs and would like to know where to put the tags. Thanks! Paul
Attached is a pic of the car.
69 Camaro SS L78 M21 4:10's
Old 03-30-2005, 06:20 PM
Belair62 Belair62 is offline
Default Re: Spring Tag Questions??
Cool car Paul...can you shrink that shot to 640x480 and re-post ??
Old 03-30-2005, 07:00 PM
Another resized pic.
Paul
69 Camaro SS L78
Old 03-31-2005, 07:08 AM
Jonesy's Avatar
Jonesy Jonesy is offline
I found my original coil spring tags on the third from the bottom coil. 69 LA car
Old 04-01-2005, 06:54 AM
After Installing the restored rear leafs, I checked out the front coils and lo and behold there was the original spring tags. They were light blue with black letters and read "YP"
Just curious what other Camaro owners, particularly 69 models, have found as far as original spring codes for the front and rear of their cars. Please list engine size and Hp. Thanks, Paul
69 Camaro SS 396 L78
Old 04-01-2005, 07:26 AM
YP is Coil #3955722 &amp; was used as the Std. on 1969 Camaros w/L34-L35-L78 engines.
Old 04-01-2005, 07:29 AM
Jonesy's Avatar
Mine were light blue with EK followed by 3955710. 1969 RS/SS 350/300hp which matched my build sheet. Build sheet says BK springs on the rear.
Old 04-01-2005, 03:36 PM
Since my rear spring tags were missing, what rear spring codes would most probably go with the front YP code springs for a 396 L78 Camaro? My car has the 5 leaf rear springs.
Thanks, Paul
Old 04-01-2005, 08:20 PM
Hotrodpaul;
Try this spring calculator: Chevynova.org 1969 Camaro 12437 L34 L35 L78 Spring Decoder
Then go here to look up the part number: 1969 Spring Part number Identification Chart
The calculator is based on the information found in the parts manuals.
If anyone has original spring tags, let me know. I am looking for high resolution pictures or scans for the database. I can then update the chart with tag color.
And for anyone else who needs them:
Chevynova.org 1969 Camaro 12437 Z28 Spring Decoder
Chevynova.org 1969 Camaro 12437 L48 L65 Spring Decoder
I built the orignal calcultors for 69 and 70 Novas, but the Camaro shared many of the same springs so these were easy to set up. Have fun with them,
Greg
Old 04-01-2005, 08:45 PM
When I remove the front springs I will send you some high res pics.
Paul
