Old 03-25-2005, 05:42 AM
69RSLM1 69RSLM1 is offline
Default Nova vs. Camaro subframes
What is the difference between a subframe from a 69 Camaro vs. one off of a 68-72 Nova? I read in the Camaro Restoration Guide by Jason Scott that contrary to popular belief, Camaro and Nova subframes are not truly interchangeable. (page 108) I was always under the impression that they were identicle. I need to replace the subframe on my 69 Camaro and was looking to buy one the was off of a Nova. Can someone shed some light on this matter. Thanks.
1969 RS LM1
Old 03-25-2005, 07:31 AM
budnate's Avatar
budnate budnate is offline
Default Re: Nova vs. Camaro subframes
if a Nova one will work..you can have a free one here in Wa..take your pick a 68 or 69 under 4dr cars
Old 03-25-2005, 07:48 AM
Thanks Budnate! But your a little bid far. I'm in Southern California. Thanks for the offer. I still need to find out whether they are truly the same subframe.
1969 RS LM1
Old 03-26-2005, 07:12 AM
bkhpah bkhpah is offline
You will most likley find the big differnces in piercings and some location holes, but not much else. You can add the needed holes or weld shut unwanted ones. The lower control arm snubber points are different on 68 VS 69, but that can be changed out as well. The Nova uses a thick washer under the firewall mounting location. You should be able to make it work...BKH
Old 03-26-2005, 07:20 AM
Belair62 Belair62 is offline
Call GMsports Salvage in San Jose...ask for Larry....search on users list here on the site for the website..the phone number is there.
Old 03-26-2005, 07:57 AM
Ask for Steve.
