Old 03-10-2005, 05:05 AM
John's Avatar
John John is offline
Default engine codes for marine motors
...saw a 427 motor ( 1968 ) with a code of "BJ" on the front pad....4bolt main motor...
Is there anywhere that list the codes for "Marine Motors"
Old 03-10-2005, 05:08 AM
John's Avatar
Default Re: engine codes for marine motors
this is the casting number ... 3955270.
this is on the front pad....T1207BJ.
The casting date is I 4 8 (September 4, 1968).
Old 03-10-2005, 05:11 AM
JChlupsa JChlupsa is offline
whats block casting and date. Also only BJ code i can find is
1981 BJ 305 LG4 H 150 4 Firebird/Omega
Ill check some other books after I get home tonight.
www.mortec.com shows it as
3955270....427.......69......2 or 4 bolt
Old 03-10-2005, 06:07 AM
rpoz11's Avatar
rpoz11 rpoz11 is offline
Yenko Premier Member
"270's" are typically Corvette 427 Blocks. I had one that was an IF or something like that, with an "I_" , but it didnt show up on any Vette lists...Good Luck!
Chavez Ravine
Old 03-10-2005, 04:29 PM
drdave69 drdave69 is offline
Maybe that "BJ" coded engine belonged to Hugh Hefner.
Dave
1987 Grand National
Old 03-10-2005, 04:51 PM
John's Avatar
..I also saw a 1968 427 , ( 321 casting number,
....4 bolt main motor with a "BP" code
...would that be "Baldwin Performance"?
..wishful thinking....
Old 03-11-2005, 07:59 AM
I was thinking maybe slick Willie!!! You beat me to the punch-line.
Lynn
