Old 03-06-2005, 07:52 PM
MosportGreen66's Avatar
Default Hidden Vin #.. '70 Chevelle
My buddy just picked up a 1970 Chevelle, no motor, trans, or tags. A typical New York City stolen recovery. The car *appears* to be a Super Sport. We're trying to figure out if it truly is. Can any anyone (cough* Rick *cough) shed some light as to where the hidden VIN #s are in a 1970 Chevelle? On the frame rails...?
Also what other clues indicate a Super Sport? Large diameter fuel line? It has a 12 bolt rear, A/C, and white stirpes. Thanks very much guys!
-Dan
Old 03-06-2005, 08:11 PM
Default Re: Hidden Vin #.. '70 Chevelle
Nothing is definitive,you have to look at the sum of the results.VIN# won't tell you if it's a Super Sport,but you know that.
If the rearend is authentic to this Chevelle,what is the suffix & date code on the passenger axle tube?
Transmission suffix too if it has.
Round gauge dash cluster?
Is there a Tach..redline?
Did you remove the engine compt.heater box to look for a VIN#?
Also aim for the frame rail over the Drivers side rear wheel.Sometimes that and the complete rear Frame rail running parallel to the rear Bumper will show a VIN#,but the Body has to be off the frame to find these.
Look at the steering shaft.Does it have a removable connection into the box,or is it solid?
Another indicator,if it had a Flapper SS hood,look at the Firewall behind the coil,(Better diagram in ASS. Manual),for a hole where the Cowl induction relay would have been mounted.
There are so many things to look for,can't list them all in Detail here.
Old 03-06-2005, 08:13 PM
Mr Yenko Mr Yenko is offline
The last part of the Vin # is under the heater box. I have seen them under the lip of the lowerend of the heater box cover.
The "Mayor"
"POTTER BROS. SUPERCARS"
72 Nova SS "My first car of 30yrs"
70 LS-6 Chevelle Double Blk 30k survivor
Old 03-06-2005, 08:21 PM
Thanks a bunch gentlemen! I will relay the information.
