Old 03-05-2005, 09:37 PM
GRB GRB is offline
Default Speaking of garage floor paint...
I was sold on U-Coat-It but I have heard the Lowes Rustoleum epoxy and prep does a great job too. And the Lowes system cost about 50% less than the U-Coat-It. Anybody had any experience with either? Got to do a work room to for a total of about 1,000 sq. ft.
I will prep it right!
99 HOSS HT
02 SS Blk 1LE A4
02 **** ZL1 Phase II+
02 SS 23mi. 500 ci
Old 03-05-2005, 11:01 PM
Belair62 Belair62 is offline
Default Re: Speaking of garage floor paint...
10 years ago I did my floor in Rustoleum 2 part epoxy...prep is the key...it still looks decent...tires or grease or ...nothing seems to affect it except for carbide snow mobile studs !!! Got rid of those long ago....you may gaet a small chip if you drop a heavy tool on it ....its as tough as steel though...
Old 03-05-2005, 11:08 PM
JK396 JK396 is offline
any additional suggestions on prep? besides instrutions on rustoleum booklet. thanks johnny katt
Old 03-05-2005, 11:13 PM
That was the worst part...make sure it is very very clean and degreased...especially an old floor...I had to use Muriatic acid...careful....and rinse the living crap out of it and let it gas off a few days or a week...any pores with acid in them will create a small bubble during epoxy cure...I put mine on real smooth with a squeegee...don't get trapped in a corner !
Old 03-05-2005, 11:23 PM
NEW FLOOR,HADN'T HAD A CHANCE TO EVEN FINISH WIRING THE BUILDING
Old 03-05-2005, 11:27 PM
Let the concrete CURE and keep it CLEAN for a good while and you should wind up with a perfect floor...but let the concrete cook itself out...
Old 03-05-2005, 11:30 PM
I had a problem with a floor that was pored in the winter. They added Calcium to keep the concrete from
freezing. The finish started blistering a few months later. If your floor was poured in the winter it will have
to sealed before coating it. I am finding this out the Hard Way….
Kentucky Gold 70 SS/RS L78.
81 Z/28 Silver/Silver Int
09 G8/GXP #992
83 El Camino
Old 03-06-2005, 12:11 AM
GRB GRB is offline
I think Rustoleum makes a sealer. I was planning on using it just in case. I'm thinking about a fairly light color and putting some of the colored flecks in it. I would like to do a dark color but they just don't reflect enough like when you are under a car. Do they?
My garage floor has been poured for about two months and I won't have it painted until May. I'll give it plenty of time before putting a car on it. I'm putting in two lifts and I'm thinking about painting it before installing the lifts. Or maybe I should put the lifts in first??
99 HOSS HT
02 SS Blk 1LE A4
02 SS 23mi. 500 ci
Old 03-06-2005, 12:33 AM
Just be careful slididn the lifts around or throwing around the steel when it gets installed. Did you happen to use the fiber re-inforced concrete ?? That would stop the problems with spalling that 70 L78 is having...
Old 03-06-2005, 01:21 AM
If you are getting your basic four post lifts, most come with wheels to roll them around for positioning. As long as your driveway is level, you can assemble them in the driveway and then roll them into position. I would finish the floor before putting in the lifts, and roll them in over some cardboard to their final resting place.
