Old 03-02-2005, 05:31 AM
Default Industrial Floor sweeper
Tennant 6100 Rider Sweeper.
Slightly used with ONLY 80 hours of use on it since Brand new.
Contact:[email protected]
Retails for $13,000.00
Selling Price:$6000.00
The Model 6100 rider sweeper easily handles congested industrial facilities, narrow-aisled warehouses, and many other applications. Designed to clean various surfaces from smooth concrete to finished floors, the 6100 can also be used on carpets. It’s ideal for picking up small debris and light litter. And as one of the smallest rider sweepers in the world, the 6100 is an excellent value.
VCS™ System: Breakthrough Filtration Technology
The patented VCS™ system filter-shaker saves time and labor. It cleans the filter panel pleat by pleat for the most effective clean-back in the industry. The VCS™ system improves overall performance by enabling the Model 6100 to run longer between filter cleanings. Manual filter-cleaning time is reduced or eliminated altogether.
Productivity-Enhancing Options
The cleaning capacity of the Model 6100 can be tailored to fit the application. Adding a second side brush extends the cleaning path and gives you an edge-cleaning tool on both sides of the unit. Plus, a QuickMop™ feature provides light cleaning and widens the cleaning path to 5-1/2 feet (1.67 m), making the small Model 6100 the largest-capacity unit in its class. The vacuum wand picks up stray litter, with vacuum suction starting instantly when the wand is pulled from its holster.
