Old 02-17-2005, 05:05 AM
1969camarors427's Avatar
Default Deep groove water pump pulley GM 3995647AP
Could someone let me know what this pulley fits other than the 1970 Z/28 350 370HP engine. The gm catalogue says 454 but does not specify which engine. It is stamped 3995647AP on the flat outward facing side of the pulley with a P right across from the part number. Is this the same one on the 1970 L78 camaro engines also. iI thought the LS6 used an 060 pulley. Did the LS6 use 2 different pulleys. The pulley is definately deep groove. Thanks.
