Old 01-17-2005, 04:50 AM
waynemiller waynemiller is offline
Default 69 Camaro BB Frame mnts
I install a 502HO in my 69 Z, I bought frame mounts from RicK's and they don't fit. The motor mounts won't line up(way off). I reinstalled the small blk mnts and got the engine in. The oil pan is resting on the frame. Does anybody have a GM pair of frame mounts? I have been looking but have had no luck.
Wayne
BlownZ
Old 01-17-2005, 08:16 PM
William William is online now
Default Re: 69 Camaro BB Frame mnts
First of all you will need a bb crossmamber if the car has a T400; manual trans can be made to work with the sb crossmember.
67-68, 69 frame brackets and motor mounts don't interchange. If you have 67-68 bb frame brackets you must use 67-68 motor mounts. 69 bb frame brackets must use 69 motor mounts. A bb will fit on sb brackets but exhaust, power steering, radiator, etc. will prove to be a headache.
I believe all crate bbs use a 5 quart pan which does not fit a Camaro/Chevelle chassis. Chevy doesn't offer a 4 quart pan for later bbs but the aftermarket does.
Old 01-17-2005, 08:28 PM
Racefan Racefan is offline
Not wanting to hijack a thread, but will sb frame mounts work on a car WITHOUT PS or PB? The engine doesn't need to move over to clear the PS pump, and the lack of power booster should provide room for clearance......right?
Phil
'68 YENKO CLONE PROJECT
Old 01-18-2005, 02:08 AM
They will; some 427 dealer-converted '67 Camaros were done on sb brackets. But even with manual steering there is very little room for headers. On 67s I believe the LH rocker cover cannot be removed due to interference with the wiper motor. Manual trans cars may require a modified Z-bar.
Old 08-12-2006, 11:02 PM
zl12iv zl12iv is offline
Will 70camaro bbc mounts work in 69 camaro....for small block..?
70 RS Z28 400TURBO hugger
69 427 L89 400TURBO 12bolt BV
Old 08-12-2006, 11:19 PM
Rick H Rick H is offline
Yenko Premier Member
No, different subframe.
Rick H.
