Old 01-09-2005, 04:40 AM
jfkheat jfkheat is offline
Default White vinyl top?
What is the best way to clean a white vinyl top? What products work best?
Thanks, James
1968 Beaumont SD396
Old 01-09-2005, 06:30 AM
JChlupsa JChlupsa is offline
Default Re: White vinyl top?
James,
We had this same topic over on Team Camaro.
http://www.camaros.net/cgi-bin/forum...c/3/2724.html?
Chris Edwards did his and it turned out great. If you go to his site and then click on exterior and then scroll down towards the bottom of the page it will show you what he started with and what he ended up with. There are some other good thoughts on the topic as well from others on that post
http://www.67rs.com/macphreak4evr/
Old 01-09-2005, 06:51 AM
Thanks Jeff. I don't think I want to take a wire brush to my top but a stiff nylon one should be ok.
James
1968 Beaumont SD396
Old 01-09-2005, 07:01 AM
budnate's Avatar
budnate budnate is offline
detail shops sell a stiff brush that goes on your Makita buffer...works awsome!!! saves the arms for shifting when you are done...I did not read the thread but good old Comet with a dab of water and the power brush cleaned a couple scrungy white tops around here years ago...
Old 01-09-2005, 07:34 AM
427TJ's Avatar
427TJ 427TJ is offline
Might wanna' be real careful with Comet washing down over your paint. Maybe mask-off around the top and cover the paint with plastic sheet? I used to use Comet with a scrub brush on white-lettered tires and it really worked, but over time it slowly took the factory clear coat off the aluminum wheels. Just a thought.
Old 01-09-2005, 08:09 AM
DjD DjD is offline
Check out what these guys say about vinyl...
http://www.303products.com/main.php?...=allaboutvinyl
Dennis
White Wonder
Old 01-09-2005, 11:12 AM
JoeG JoeG is offline
Bud's right about comet on a funky top, guys did use it, but it's not something you would want to do on a regular basis--even used bonami back then and you must use a vinyl conditioner afterwards--One product I've used since my car was new was Murphy's Oil Soap--mixed in warm water for top and car. Once the top is clean I never used anything but a terry cloth rag/pad to clean and condition the top. They are correct there is a skin to a vinyl top.-----------
Old 01-09-2005, 11:43 PM
Belair62 Belair62 is offline
Wesleys Bleche White works pretty good if you are careful....hey anyone ever use Kleer floor wax on their vinyl tops to make them look nice and shiny !!!
Old 01-10-2005, 12:09 AM
I have.
The floor wax yellows &amp; cracks over time.
Old 01-10-2005, 12:19 AM
Thats because you didn't strip it like a floor with ammonia !!!...used to do the tires too before armor all !!! The ammonia wasn't real pleasant to work with...how about lemon Pledge on the interior...kinda slippery but came in handy sometimes
