Old 01-03-2005, 02:01 AM
4276bbl 4276bbl is offline
Default how to id a big block?
hey fellas, i'm new here! is there a thread about how to determine a 427 from a 454etc.. my buddy has a motor he thinks is a 427, has a cast# 3963512--conv 1 L8-9
says hi perf-pass g can someone please decifer this?
thanks steve
Old 01-03-2005, 02:25 AM
DSYenko DSYenko is offline
Default Re: how to id a big block?
Im no expert but a 512 block can be either a 454 or a 427.But with a "L" casting date im guessing 454.What would help is if you know the info stamped on the deck ahead of the drivers side head.
EX 81 YENKO TURBO Z owner
Old 01-03-2005, 05:54 AM
Unreal Unreal is offline
427 is internally balanced, and 454 is externally balanced. If the balancer has a counterweight cast in the back side, it's a 454 balancer. Look for engine codes on the pad in front of the pass side head. Based on the cast date, if it's a CE, it could be either a 427 or 454. If it's a standard engine build date/application code, it would be a 454.
