Old 12-11-2004, 08:47 PM
Jeff H Jeff H is offline
Default Pressure washer advice needed
We're planning on getting my dad a pressure washer for Christmas so I was wondering what to look for and what to look out for regarding pressure washers. Is there a certain level of power/pressure that is worthless or too weak for most washing/cleaning. Looking for opinions, thanks.
Old 12-11-2004, 11:59 PM
427TJ's Avatar
427TJ 427TJ is offline
Default Re: Pressure washer advice needed
My opinion is that it's best to spend a little more and get more pressure. I spent the additional 100 bucks and got a 3000 psi/7.25 gph model for general household use and it's great. It made short work of my backyard patio and my three-car wide driveway plus the spray reaches up to the second floor outside walls of my house to knock bird crap off. The patio and driveway now look like fresh concrete. The backyard fence needed painting so I first hit it (carefully) with the pressure washer and knocked off the loose paint. Beats the heck out of having to sand/scrape 100 feet of fence. One thing though---wear ear protection. After working on the driveway for 30 minutes I needed to put in earplugs because of the motor noise.
Old 12-12-2004, 12:18 AM
Pantera Pantera is offline
Be sure to drain the hoses and pump after you use it so that it does not rust up. some brands will not work a year or so later if you forget to clean it up. Not to mention it may freeze and burst if your storage area is not heated enough.
(Don ask how I know that)
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 12-12-2004, 02:53 AM
budnate's Avatar
budnate budnate is offline
we bought the 400.00??? dollar unit from Home Depot for work, with the 5hp brigs on it...the grunts beat the snot out of it and it keeps on ticking..plus it had this option of hooking chemicals on the side and it would suck them through and mix with the water...Mom has one of those phony elec 80 buck units basically good for knocking the dirt off the truck and thats it,POS.
Old 12-12-2004, 03:25 AM
DaveC68's Avatar
DaveC68 DaveC68 is offline
I've been told the "true" way to compare one pressure washer to the next is to use the following formula between brands/models.
(psi*gph)brand X vs. (psi*gph)brand Y
Of course the one with the higher total is pressumed "better".
Dave C.
68 SS396 Camaro
69 SS396 CB Chevelle Conv.
70 340 Dart Swinger
70 SS396 Chevelle 4spd
70 SS396 Chevelle
70 BB 4spd Monte Carlo
70 SS454 Monte Carlo
71 SB 4spd Monte Carlo
71 SS454 Monte Carlo
71 Corvette LS-5 conv.
71 Corvette LT-1 conv.
71 Corvette LS-6 coupe
72 Monte Carlo
72 Monte Carlo Custom
72 442 W-30 clone
76 Trans Am SE 455 4 spd
85 Mustang GT Conv.
86 Grand National
02 SS conv.
Old 12-13-2004, 07:40 AM
I am with Budnate,the 400.00 ones from Home Depot work good.I have had one for 4 years now and it works great. I Especially like the chemical mixture device.I use mine for almost everything and it still works great.I do prefer Honda engines but I have never had a problem with thee old Briggs and Strattons.
Bobby Dodson
Old 12-13-2004, 05:02 PM
drdave69 drdave69 is offline
I have one of the $400 units from Lowes that has a Honda engine. I believe it's 2800 PSI. Works great. The only problem is the pump. The long bolts holding the pump housing together seemed to have rusted, thus, allowing a few of them to break. This resulted in me having to disassemble it and replace the pump oil. Quite a pain. A friend had the same thing happen.
Dave
1987 Grand National
