Old 11-17-2004, 03:39 AM
Default Seat belt codes
Been having a discussion over on TC about seat belt codes. Take a typical code like 26-C-68. I'm pretty sure the 26 is 26th week, and the 68 is the year, but what does the letter code indicate. My Chevelles have codes A,B,C, F, and K. All 6 rear (male and female) belts in my 68 are 14-C-68. Has anyone here researched this and find out for sure what these letter codes are. TIA.... Bill
69 El Camino
69 Nova
C7 Vette
Old 11-17-2004, 03:59 AM
hugger_69 hugger_69 is offline
Default Re: Seat belt codes
Bill,
There have been a few debates on this letter over the last couple years and most agree this is a plant code. Here is a link to an old TC thread that may help answer your question as well as one about the model numbers.
http://www.camaros.net/cgi-bin/forum...c/6/3505.html?
http://www.camaros.net/cgi-bin/forum...c/6/4303.html?
Hope that helps you a bit.
Graeme
1969 Documented Z/28
1968 Documented RS (Z/28 Clone)
Old 11-18-2004, 01:36 AM
P.J. P.J. is offline
I get a bad getaway message on both threads,
Peter
Old 11-18-2004, 02:22 AM
Kurt S Kurt S is offline
Either plant code or assembly line code.
Kurt S - CRG
Old 11-18-2004, 03:11 AM
KevinW KevinW is offline
Kurt, I liked the line codes first, but after seeing some "C" rear hammils from impalas and rear "C" from camaros and they were different lengths! I would think the car model should dictate the line. Maybe it was section inside a plant? like "C" section
BTW Team Camaro and team Chevelle appear down.
69 327 convertible (driver)
Old 11-18-2004, 07:02 AM
budnate's Avatar
budnate budnate is offline
guys I am by far a seatbelt expert but I just went through the belts on my cars and restored a set for the 67 this last year and they were sewn by humans in a darn hurry back then...all the ones I have seen are different lengths even if they are from the same car..I am guessing they may have started out with a set length but by the time they folded the ends and such by eyeball that's what we ended up with ...I have measured them as much as 8/10" off in lengths and the tags are all over the place..if I did'nt know better I would say they were sewn in Taiwan new...I would like to read those other threads and compare the notes I have.
Bud.
