Old 11-09-2004, 03:49 PM
RS69 RS69 is offline
Default Motor codes
I have a motor i picked up from a state trooper car. It's a 350 (5.7) and no one at my local chevy dealer can help me with the codes. it has a steel crank, pink rods, 4bolt main, roller cam, lifters etc.. the motor has never been apart. here are the numbers. on the front pad is the following: VO125BMA rear of the motor: 14093638 the heads are: 14102193 (gm20) drivers side, 14102183 (gm19) pass side. any help would be great. thanks
Old 11-09-2004, 10:26 PM
396L35's Avatar
396L35 396L35 is offline
Default Re: Motor codes
The engine code says it could be camaro 1987 or truck 1986 or 1987. As for the heads I have no listing on them, the camaro heads for 87-up list as 14102191. I hope this helps, Mark
Mark
Old 11-09-2004, 10:50 PM
JChlupsa JChlupsa is offline
http://www.nastyz28.com/sbchevy/sbch.html
1986-88 14102193 350 1.94 1.5001 - EFI
Old 11-09-2004, 11:09 PM
Thanks alot. That helps. i was trying to figure out what i had. i'm putting a tpi on top and installing it in my 34 3window.
