Old 10-17-2004, 06:54 AM
All American Racer All American Racer is offline
Default 69 Yenko Nova ?s
Hi Guys, I have been able to find pictures of 4 different 69 Yenko Novas on this site. Do you guys have any more? I also noticed Brian Henderson's looks strikingly different than the other 3 I found. Did Yenko remove the "396" fender tag and put in his own 427 badge in the same holes? I think that is a 396 emblem on Brian's car. Any links or posts of detailed pictures of one of these cars would be greatly appreciated. Marc
Attachments - The Supercar Registry 104191-Nova-5.jpg 103619-69YNovaKSuydam-4.gif 103273-69YNovaKSuydam-3.jpg 103272-69YNovaKSuydam-2.jpg
Old 10-18-2004, 12:56 AM
Default Re: 69 Yenko Nova ?s
That's a darn good question Marc, and to tell you the truth I don't think anyone has a definitive answer to that. The '69 Yenko S/C 427 Novas are unique in the '69 Yenko lineup in that they were not COPO'd factory installed 427s like the Camaros and Chevelles, but were instead converted from RPO L-78 SS396 cars very similar to many of the Yenko 427 Camaros in '68. Being that they were SS396 cars to begin with, looking very much like this (with the possible exception of the brightwork around the windows and rockers) they all would have received the cast front fender marker light bezels with "396" engine identification from the factory.
While it isn't completely known for sure how Yenko then rebadged these cars as 427s, it seems there were at least 2 different practices used. The stock 396 bezels were sometimes removed, and replaced with smaller, plain bezels with no engine size, as used on 6 cylinder Novas in 68-9. Then Yenko's crew would add their own 427 emblems ahead of the bezels, doing their best to cover/utilize the extra hole where the original 396 marker bezel had been factory installed. This method required the installation of 2 new parts per side, a new plain marker light bezel and Yenko's own designed 427 badge.
The other method of correcting the "396" marker light bezel problem, was to simply remove and replace the "396" bezel with a cast GM "427" marker light bezel as used on big Chevrolets in '68. The latter made for a cleaner, neater, more factory like appearance, but may have been more expensive, so Yenko may have favored the use of his own 427 emblems more often. This is only speculation on my part.
Being that so few of the '69 427 Yenko Novas exist today, and most lived very hard lives and were subject to lots of abuse and modification over the years, there is little to go on in terms of unmolested surviving examples to give us the definitive answer we're looking for. Not to mention that each car was hand converted and things like emblem and stripe placement variations abound in Yenko's "process" for converting supercars.
To add to this mystery, I know of only one surviving period photograph of a '69 Yenko 427 Nova, and unfortunately it is a rear shot of the car on a carrier and the fender emblem placement cannot be determined.
I guess these "unknowns" only add to the mystique of these incredibly rare supercars. Maybe someday we'll luck out and an unmolested, "undiscovered" car will surface. Until then, I hope at least some of my explanation is helpful.
Old 10-18-2004, 02:03 AM
camarojoe's Avatar
A third possible option for 427 identification would be the one Dick Harrell used on his cars in 68... He ordered the early 68 production "tinfoil" inserts for the 427 bezels and glued them right over top of the cast 396 portion of the existing bezel. If these thin inserts were still available through GM in 1969, Yenko could have also did this to the Novas, requiring them to only add an insert to the existing emblem, and would not even require the removal of the bezel, and make the "conversion" that much quicker and easier. Just a thought.
Joe Barr
Old 10-18-2004, 02:22 AM
Thanks for the insight guys. I'm really striking out in the photo department though. I have shots of Henderson's, Hand's, Holub's, Reggie's, and one from this site that doesn't list an owner. No detail shots at all. Time for some aspiring author to write a book. Marc
Old 10-18-2004, 02:45 AM
Jeff H Jeff H is offline
I believe Henderson's car was not a 427 conversion at Yenko. Correct me if I'm wrong guys, but I thought that car was sold as a 396 car and the 427 engine was later swapped in. The original owner cancelled the conversion or couldn't afford it so took delivery of the car as an SS396. So using that car as a template might be incorrect.
Old 10-18-2004, 06:00 PM
Hand sold his car several months ago to DaveC, and Reggie sold his over a year ago to KeithH.
Erik explained it very well, both methods appear to have been used by Yenko. I'll post some as found pics tomorrow of 2 '69 Yenko Novas, but I can't remember if the one has a fender shot or not - but the rear tail panel is quite interesting!
Old 10-18-2004, 08:02 PM
Here's one, maybe one of you guys can make out the front bezel setup.
Old 10-18-2004, 08:13 PM
These are even harder to make out.
Old 10-18-2004, 08:14 PM
Old 10-18-2004, 08:53 PM
Plenty of reading material in the archives!
https://www.yenko.net/ubbthreads/show...art=1&vc=1
