Old 10-16-2004, 04:58 AM
92646 92646 is offline
Default 1969 302 motor, 618 4-bolt block, 186 heads
This motor has been rebuilt and not used since then. It is a 618 4-bolt block that was cast in Feb.1969. The 186 double hump heads were cast in Feb.1969 and Sept.1969. It has the 3279 steel crank, 140 off road solid lifter cam, 12 to 1 forged pistons, high volume oil pump, roller timing chain, large harmonic balancer, Z/28 oil pan and windage tray, Z/28 aluminum valve covers and 472 Z/28 aluminum intake manifold. The motor is on a stand and available for inspection. $5,700.00 e-mail me if you have questions or you want more pictures.
