Old 10-12-2004, 03:40 AM
RED427 RED427 is offline
Default Body # and Build date
I was at a car show in ohio OCT 1-3 and i located a 1969 Garnet Red Z-28 with a body # 3 car before my car but
it was built 04c ( April 3rd week ).My car 05d may 4th week.
why the long time frame between these cars??? <font color="red"> </font>
Old 10-12-2004, 04:08 AM
JChlupsa JChlupsa is offline
Default Re: Body # and Build date
Are they both Norwood cars?
APPROX VIN's for build months
<font color="red"> NOR </font> <font color="blue">LOS</font>
<font color="red">April 1969 623588 637106 </font> <font color="blue"> 528109 530155 </font>
<font color="red"> May 1969 637107 650323 </font>
Old 10-12-2004, 05:38 AM
Both car are norwood car <font color="red"> </font>
Old 10-12-2004, 05:51 AM
berger berger is offline
looks like his car was the last built before the 69 strike, and yours was the first built after the strike.
67 Rs modified stormer z28 482cu in.yenko camaro
67 327 camaro
69 SS 396 camaro
Old 10-12-2004, 06:35 AM
I TALKED TO GUYS THAT WORKED THERE IN 1969
I WAS TOLD THAT THERE WERE NO STIKE IN MAY 1969
Old 10-12-2004, 04:16 PM
COPO COPO is offline
Often the COPO body numbers lag the "run of the mill" camaros and don't line up.
Old 10-13-2004, 01:02 AM
I believe I read here somewhere, that a car was assigned a bodynumber when the order was accepted by Chevrolet. So it would have little to do with when it was built.
Am I wrong ?
Experts come forward !
Anders
Anders Stålklint.
Old 10-13-2004, 01:13 AM
firstgenaddict's Avatar
Body numbers were assigned by Fisher.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 10-13-2004, 04:17 AM
Mark_C Mark_C is offline
69 body numbers are the order number assigned by GM after the order has been checked and approved by the factory. After the order was approved and the number assigned it was sent back to the ordering dealer with an approximate build date. The order was then sent to the appropriate factory for building. The cars were then scheduled for building based on availability of the parts necessary to complete the car. Cars with low production options, or special paint colors usually had a longer gap between order acceptance and build date resulting in body numbers jumping all over the place. The body number was assigned by GM as it was the only number assigned to the car prior to it being built, but it was stamped by Fisher. VIN's were assigned to the cars in the GM Body Bank area as they came over from Fisher to the GM side of the plant. The VIN's were basically handed out in numerical order as the cars came thru the hole in the wall.
CRG Camaro Assembly Process Page
No Norwood strikes in 1969. LA Struck April 29th till July 19th and only reopened to finish the cars that were actually partially assembled on the line already, which contained roughly 800-900 Camaros.
Mark C.
My Pace Car
Old 10-13-2004, 04:54 AM
indyjps indyjps is offline
i bet those 8-900 cars were real cherries with employees fresh off a strike.
69 camaro
