Old 10-09-2004, 06:59 AM
budnate's Avatar
budnate budnate is offline
Default '69 cowl induction system
'69 cowl induction system---
-- repop air cleaner assembly complete...
--orig 1969 components... wiring harness, Flapper with solenoid, Cowl relay, Cowl throttle switch, Throttle arm, pulled from a car when they tubbed it and went racing..I believe its all there..the guy gave the air cleaner a slight ding from the underside around the throttle area I guess for a solenoid?..you cannot see it until you flip it over and if it had paint on it you definatly would probably miss it. check out the pics you can see the wiring and components have a little dirt on them and appear to be in orig finishes.
first $250.00
Thnx Bud.
Attachments - The Supercar Registry 101643-69 flapper4.JPG 101642-69 flapper3.JPG 101641-69 flapper2.JPG 101640-69 flapper.JPG
Old 10-09-2004, 07:00 AM
budnate's Avatar
Default Re: '69 cowl induction system
a
budnate's Avatar
b
Old 10-09-2004, 07:01 AM
budnate's Avatar
c
Old 10-10-2004, 04:06 AM
budnate's Avatar
SOLD........
