Old 09-11-2004, 10:00 AM
dreemz dreemz is offline
Default 1969 Chevelle front grille
Is the front grille on a 1969 Chevelle the same for either a standard, COPO, or SS car other than the SS396 badge or the bow tie? Would it be the same for an El Camino?
Old 09-11-2004, 10:04 AM
GTO_DON GTO_DON is offline
Default Re: 1969 Chevelle front grille
I believe "yes"
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 09-11-2004, 06:31 PM
Don_Lightfoot's Avatar
Don_Lightfoot Don_Lightfoot is offline
Need to clarify this, sorry Don. The Malibu, SS and El Camino grills would have been the same - they would have holes in the horizontal center bar for attachement of the aluminum molding. The grill for 300 Deluxe models did not get those holes or the molding. Hope this helps.
Specialized Chevrolet Decals
Old 09-11-2004, 07:12 PM
I was just speaking in general. how often do you even see a 300 grille? and you could probably drill the holes in it anyway to put the mouldings on.
Old 09-11-2004, 08:23 PM
camarojoe's Avatar
The 300 Grille is not the same as the SS grille, and I don't just mean the holes... the entire center bar area is different, and where the aluminum trim on the SS and Malibu grill would be, it s molded plastic on the 300 grille. You COULD drill it and put the trim on, but it would then stick out too far. The only available over the counter GM grille for 69 has been the 300 version for well over 20 years, so you will see MANY 69 SS cars with 300 grilles and the trim attached incorrectly on top of that, but recently they started to repop a more correct SS/Malibu grille with the lower center bar. No idea if it fits as bad as repro parts usually do, but it looks good in the pics I've seen. From what i know, the Malibu and SS grille is the same, the only difference being the way it is painted. Search the Team Chevelle site for more insight and pics of the differences, I know this has been discussed over there on numerous occassions. -jb
Joe Barr
Old 09-12-2004, 04:57 AM
Thanks guys for the info. So how would you determine, assuming we're talking NOS parts, that the grille is not the GM 300 type grille that has been made for the last 20 yrs as pointed out above, and is appropriate for a COPO or SS car? Is there a specific part # assuming I can't look at the grille first?
Old 09-12-2004, 06:44 AM
camarojoe's Avatar
I don't know the part numbers off hand, but if it is an NOS GM grille, I will almost guarantee it will not be correct for an SS, COPO, or Malibu, and will be the 300 style grille. I have never seen an NOS GM one that was not.
Joe Barr
Old 09-12-2004, 08:44 AM
Here are the original part numbers I have from one source which is normally fairly accurate.
3938180 - Malibu, SS, COPO, Elky.
3938106 - 300 Deluxe.
3942789 - Nomad Wagon.
Old 09-12-2004, 10:21 AM
camarojoe's Avatar
Just out of curiosity, what is different about the Nomad Wagon grille from the rest? If memory serves correctly, I think the Nomad used a grille like the 300, but was completely naked, with not even a bowtie in the center... my guess is its the same grille, with no emblem holes in the center. Anyone confirm this?
Joe Barr
Old 09-12-2004, 06:43 PM
What is different about the Nomad Wagon grille from the rest?
Can't answer that for you Joe
