Old 08-31-2004, 12:04 AM
rickp rickp is offline
Default 1970 Charger R/T Questions
My partner and I, recently aquired a 1970 440 R/T 4sp. car. The car has a 750 Holley carb which I assume is incorrect (E86 code engine), but yesterday at a car show I saw a 1970 "383" Road Runner - 4sp. car, which had a 650 Holley, that the owner was sure is correct. I'm not a Mopar expert, but I believe both cars came with Carter AVS carbs. Another question I have is our Charger has power drum brakes and the code B51 on the trim tag, which according to info I have equates to power assist disc brakes. One last thing, this car has hood pins which I also do not think it came with, but I noticed the Banna Yellow Hemi Charger in Musclecar Enthusist had hood pins.
Any thoughts would be appreciated.
Old 08-31-2004, 12:35 AM
GTO_DON GTO_DON is offline
Default Re: 1970 Charger R/T Questions
Is this the b5 blue car from the chestnut hill area?? original owner?
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 08-31-2004, 06:57 AM
Comparing a 383 to a 440 is like comparing a 396/325 to a 427/425. Different motors, different intakes, different carbs. Some 383's used a Holley. The 440's used a Carter AFB. Hood pins (code J45) were an option on the 70 Chargers. If the car had PDB it would be coded B41 for disc and B51 for power assist on the broadcast sheet but not necessarily on the fender tag (My car has "B51" listed on the tag but it is a Super Track Pac car which included the B41 Disc brakes with the 4.10 gears). Either way, power
4-wheel drums sounds fishy to me. Should be manual drums or power front disc with rear drums. If it is an original 4 speed car it should also have a Dana rear. If you PM or email me the fender tag or broadcast sheet I can be tell you what the car is/was/should be. -NJSteve
Old 08-31-2004, 06:15 PM
In my recent travels, I have seen several H.P Mopars of this era with manual or power disc brakes, but none with power drum. I am fairly certain that this car is all original except for the carb. Yes it does have the Dana 60 rear, as you will detect on the fender tag. I do have the broadcast sheet and I will enter the fender tag data here.
26 END
J25 M21 M25 M31 R11 V8W
V1W A33 B51 C21 C55 G33
EB7 C6B5 EB5 917 007876
E86 D21 XS29 UOG 125126
thanks for your help, Rick
Old 08-31-2004, 06:20 PM
You're close - Germantown, but it sounds like you are familiar with the car.
Old 09-02-2004, 06:07 PM
As an additional follow up to the 440/375H.P Magnum Engine, my original question assumed we were only talking about the 440 or 383 Magnum engines (1 4bbl), not trips, 2 bbls. or pass, 4bbl engines. Another words the Magnum 440 or 383 engines as came in Roadrunners, R/T's, etc. I have learned a little since 1971 when I first looked at a 1969, 396 Nova SS which I initially thought had an aftermarket aluminum intake and a Holley carb. I learned at that time that Chevy produced this motor "L-78" and purchased the car with my 1962 Impala 2dr. hardtop 327/250 (small Rochester 4bbl carb)in trade. I still have great memories of the Nova 30 years after I sold it for $1500 in 1974, in excellent condition. In reguard to the power drum brakes on this Charger, it appears this set up is probably very rare. Why someone would opt for power drum brakes and not go the extra mile for power disc brakes is curious.
Old 09-03-2004, 12:08 AM
Pantera Pantera is offline
disk brakes were too new back then and not everybody had a good experience with them. I bet his buddy had problems with a set on another car so when he ordered his he opted for the power Drum brakes.
Remember back then "New" technogly was not as desirable as it is today.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 09-03-2004, 12:30 AM
budnate's Avatar
budnate budnate is offline
last 2 cents a lot of the guys in the know back then went with drums for less drag if they were going to run the car at the track.
Old 09-07-2004, 02:59 AM
[quote
26 END
26 = 26 inch radiator
END = end of tag sequence, begin next tag as follows
J25 = 3 speed wipers
M21 = Drip rail moldings
M25 = body sill moldings
M31 = body belt moldings
R11 = AM radio
V8W = White transverse stripe (not bumble bee stripe)
V1W = White vinyl top
A33 = Track Pak with 3.54 Dana rear
B51 = Power brakes
C21 = front "buddy" seat with fold down armrest
C55 = bucket seats
G33 = remote chrome left hand mirror
EB7 = Dark Blue
C6B5 = Blue vinyl interior
EB5 = blue door frame color
917 = Sept 17, 1969 build date
007876 = Vehicle order number
E86 = 440 4bbl Magnum 375 horsepower
D21 = 4 speed manual 18 spline
XS29 = Charger R/T
U = 440 4bbl
O = 1970
G = St. Louis assembly plant (the only plant that built 1970 Chargers)
125126 = VIN sequence number, the 25,126 car built (they always start with 1, i.e. the first car built is #100000)
I need to see line #6 on your broadcast sheet to answer the disc brake question. The A34 Super Track Pak included the power disc with the 4.10 Dana rear. The A33 Track Pak with 3.54 Dana rear may have had the same power disc option included in it. Give me more data and I can give you more answers. Hope this helps, NJSteve
Old 09-07-2004, 03:19 AM
Norm reynolds Norm reynolds is offline
The correct carb for that R/T is a carter Avs 750 cfm
I never seen one from the factory with a holley
only on the six packs
