Old 08-11-2004, 03:47 AM
427TJ's Avatar
427TJ 427TJ is offline
Default Coker redline care
I'm having a hard time making my Coker F70 belted redlines shine. They seem to have a gray-ish look to them. I use (lightly) a dash of Comet on a soft brush with water to scrub the sidewalls and then I usually apply Armor All* with a clean rag. The Armor All works great on other tires and leaves a nice show shine but not on the Cokers. Anyone have a better method of applying a nice shine to Cokers? Thanks in advance.
*This is the ONLY use I have for Armor All.
Old 08-11-2004, 04:09 AM
Default Re: Coker redline care
A little Wesley's Bleche-White and a stiff bristled brush...then finish 'em off with some Lexol Vinylex.
Old 08-11-2004, 05:28 AM
Belair62 Belair62 is offline
Are you talking about the "waxy" substance that seems to build up that is a total pain in the ass to remove permanently ???
Old 08-11-2004, 05:38 AM
427TJ's Avatar
Hey Kid--can I get the Lexol at a car parts place? I saw it available online but there's a show this weekend I'm taking my Camaro to. Oh, and I assume the Wesley's won't harm the red stripe?
Belair--yes, that "waxy" stuff is why I described my tires as turning gray after several weeks. I scrub them and work them with Armor All to subdue it then it slowly comes back. It wouldn't bother me so much if the tires were less expensive!
Old 08-11-2004, 05:42 AM
I believe in the industry,they call that BAIN.
Old 08-11-2004, 06:00 AM
...427 I have used lacquer thinner and the crap still comes back...I thought it was mold release stuff but it just keeps coming back...
Old 08-11-2004, 06:20 AM
Wesley's Bleche White is available at any auto parts store, the Vinylex is a little more "specialty" so you may need to order it online. Bleche White will not harm any tire and will make those redlines pop.
Old 08-11-2004, 08:45 AM
tom406 tom406 is offline
Bleche White (or equivalent) is key for any tire detail. The same stuff that makes whitewalls (or redline/goldline/blueline) all murky and dark makes a blackwall brown and dingy. We find that exposure to sunlight (UV?) seems to leech it out of the sidewall. Use the Bleche White, rinse, then apply your favorite tire dressing after they've dried off.
Old 08-11-2004, 08:59 AM
DOES the Bleche White take the red out of the redline?
-Sam
Old 08-11-2004, 09:05 AM
hvychev hvychev is offline
No if anything it makes it brighter. I have been using it for about the last 8 years.
Frank Magallon
