Old 07-21-2004, 11:52 AM
brumie215 brumie215 is offline
Default 327/350 block - 2.02 heads
1968 327/350 block Casting 3914678 numbers on the pad are VIOIOMA VIN:18N326381
It is a 2 bolt main, large journal block - all the caps are there/w Bolts, the block is .030 over
Numbers show for late 67 or 68 327 210HP Camaro - 75.00
Set of double hump heads #3917291 - Date code I 27 7 and J 11 7 - with 2.02 valves. There is no port work/grinding on the heads, looks like the factory springs w/dampers, has all the rockers, studs were pined at one time and has alum/aftermarket retainers. They are in nice condition 175.00
Old Ansen Steel blow proof Bellhousing for Chevy – no lower cover and has been modified for later type starter – it’s heavy 35.00
[email protected]
North Central Ohio
