Old 07-18-2004, 10:57 PM
Default carb heat shield....
Does anyone know if the metal heat shield that was used under Holley carbs is still available form GM or would I need to locate a used one. Thanks, Tom
Old 07-18-2004, 11:21 PM
Steve_Hoog's Avatar
Steve_Hoog Steve_Hoog is offline
Default Re: carb heat shield....
I don't know if it's what you want but GM did have an aluminum shield for both straight bore and spread, if it is what your looking for I will try to get you the numbers Monday at work.
Old 07-18-2004, 11:26 PM
That sounds like what I am looking for. Used to get these years ago from the local Chevy dealer. let me know what #'s you come up with. Many Thanks. TW
Old 07-18-2004, 11:27 PM
Steve_Hoog's Avatar
They have two gaskets stapled to the plate and firing order stamped, they were very cheap. I may still have one around the shop if they are discontinued
Old 07-19-2004, 12:18 AM
Sounds good let me know. How about a SW or Sun tach(see post)??? Thanks,Tom
Old 07-19-2004, 03:55 AM
mssl72's Avatar
mssl72 mssl72 is offline
I did order one from GM a few years ago for my big block/Holley set-up. They call it an insulator assembly or "INSUL ASM". Group #3.726 in the parts books. The part number on the one I have is 3969835. If this same one would work for your application, try calling a dealer and see if it's still around.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 07-19-2004, 05:20 AM
I will check it out tomorrow.Thanks.TW
Old 07-19-2004, 05:19 PM
Steve_Hoog's Avatar
Tom
I couldn't verify that the number Mark gave was correct, I had trouble figuring out where I found the numbers. I think I got them out of a magazine years ago and then found them in a GM truck parts catalog that is long gone. I do still have an old Corvette paper catalog that listed a 3969837, I think that may be the Qjet one. At any rate, they are both discontinued. I ran a locator for you and here are the dealers still showing to have one, good luck.
3969835
IND = INDIANAPOLIS, IN (317)
3969835
ID# Name Qty Date Phone 1 Phone 2 PA
111 HARMS AUTO SUPPLY ST 04/28/04 317-632-7447 800-382-1234 P
ATL = ATLANTA, GA (404)
3969835
015 BILL HEARD CHEV BUFO 00* 07/16/04 770-945-4981 800-451-2823 P
INT = THE TRIAD, NC (919)
3969835
004 FLOW CHEVROLET, INC. ST 07/19/04 919-760-7046 800-462-8458 P
YNG = YOUNGSTOWN, OH (216)
3969835
010 GREENWOOD CHEVROLET 00 07/14/04 DIR-792-5258 800-926-4977 P
TUS = TUCSON, AZ (602)
3969835
003 O'RIELLY CHEVROLET 00 07/17/04 520-747-8000
RIC = RICHMOND, VA (804)
3969835
068 LARRY'S CARLAND INC 00* 07/17/04 434-292-7285 434-292-3946
Steve
Old 07-19-2004, 09:01 PM
They're on Ebay occasionally with starting bids between $10-20.00 NOS in GM Envelope,& end with no bidders.
You can find them.
Old 07-20-2004, 07:23 AM
Thanks for the contact list I will make some calls tomorrow.
wilma
