Old 07-16-2004, 05:44 AM
skierkaj skierkaj is offline
Default 427 block and head codes needed
I recently came across what was supposed to be a 427 block, with rebuilt heads. The motor had all the bottom end components, but looks like it hadn't been touched (except for the heads) for 30 years. No intake, carb, etc., but it still looks promising. Could you guys help me with some codes I should look for, to insure that this motor is genuine, before I lay down the cash?
John "Hutch" Skierka
Old 07-16-2004, 05:53 AM
jfkheat jfkheat is offline
Default Re: 427 block and head codes needed
Here is a site where you can check casting numbers. Post the numbers off the engine pad.
James
http://www.nastyz28.com/bbcmenu.html
1968 Beaumont SD396
Old 07-16-2004, 06:08 AM
Belair62 Belair62 is offline
Here to skierk http://www.mortec.com/
