Old 06-04-2004, 03:48 AM
NCGuy68 NCGuy68 is offline
Default Tonawanda small block?
Ran across a 67 Camaro survivor. It has a L30 (327-275)and Powerglide trans. Quite a original car, but the stamped engine code is one I've never seen on a small block.
Engine Code: T1113MM.
The MM is indeed a 67 with L30 and Powerglide. I question the 'T' because it would indicate that it is a Tonawanda built motor. I have always thought Tonawanda built the big blocks and Flint built the small blocks. In addition, there is no stamped VIN sequence number on the pad.
Can anyone shed light on this subject?
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
