Old 06-02-2004, 02:28 AM
TOYVET TOYVET is offline
Default Chevy TH400 Transmission #s question
Wanted to check w/ the board...is the car's VIN stamped on 1969 Chevy TH400 transmissions for Corvettes, Camaros, etc...
Thanks
[email protected]
Attachments - The Supercar Registry 84858-turbo 400 5.jpg 84834-turbo 400 1.jpg
Old 06-02-2004, 02:35 AM
JChlupsa JChlupsa is offline
Default Re: Chevy TH400 Transmission #s question
Cant get any better than this for detail:
From the Camaro Research Group Web Site
http://www.camaros.org/numbers.shtml...missionNumbers
Old 06-02-2004, 04:09 AM
GTO_DON GTO_DON is offline
yes it is!! its up around the end of the bellhousing on the passenger side.......look hard!!
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 06-02-2004, 04:20 AM
I've seen the VIN# stamped into the TH400 on the Driver side into a 3 inch recessed machined Horizontal pad above the Pan gasket,just behind the shift linkage bracket & boot.
Or also look up around the Driver side Bellhousing mating area too.
Old 06-02-2004, 05:10 PM
lowmile lowmile is offline
Like this?? I still haven't been able to decode these numbers.
Old 06-02-2004, 06:08 PM
Mark,EXACTLY what I meant.Good Picture!
That is a perfect example of a Replacement Transmission Code,similar to a CE Engine block code.
H9T 05030 breaks down as:
H=Hyra-Matic
9=model year,1969
T=Transmission
05030=Unit Sequence number produced.
The Cleveland plant started producing at 00001 and went up to 14999,so we know it was from the Cleveland Plant.
What does the passenger side Aluminum Rectangular tag show?
Rick
Old 06-02-2004, 08:46 PM
There isn't a tag on the passenger side. If you look in the hole where the tag rivit should go, it looks like there never was one on it. The story I got from the owner at the time was, the drive shaft got thrown out in 1970 and it wrecked the original tranny. thanks for the info! m
Old 06-02-2004, 10:04 PM
That's Typical of what I have seen & heard of Service replacement Transmissions.
There were 4 Transmission plants making these,and for the following Car Manufacturers:
Buick-Olds-Pontiac-Chevrolet-Cadillac.They didn't use a Pass. side suffix tag,because they didn't know what application that trans. would be used for.
Your findings help back that up.
I Thank You.
Rick
