Old 05-05-2004, 05:36 AM
Alss's Avatar
Alss Alss is offline
Default steel wheel decode
Can anyone ID a steel wheel for me? Code XC..they are on a 69 Chevelle 300 post. The car has drum brakes all around. Will these wheels clear disc brakes? Thanks.
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 05-05-2004, 06:42 AM
Default Re: steel wheel decode
Those are 1969 Chevelle Base model rims,also used on 1965-68 Passenger & Wagons.All without Disk brakes.
I have one here that looks like it would fit.It has a one inch offset,but I can't be certain...
Old 05-05-2004, 06:44 AM
mnyenko mnyenko is offline
Albert,
Colvin shows 69 chevelle base passenger 14x5.I would think they clear power brakes.Must have been an rpo option.Earl
Old 05-05-2004, 10:39 AM
tom406 tom406 is offline
If it cross references back to '65, I'll bet it won't clear discs. They're pretty easy to identify, as the disc brake wheel outer rim pretty much stays flat from the inner wheel lip to the inside mounting surface. Drum brake wheels tend to taper inward toward the center at a slant, roughly similar to the drum that fits inside of it.
