Old 04-30-2004, 06:25 AM
KevinC KevinC is offline
Default Help on Turbo 400"CW"
Hi all,
I'm trying to identify a Turbo400 and I hope you can help. It's coded "CW" and when I look it up in the Turbo 400 Trans. book it shows a 1970 Chevelle with a 400ci.engine. The person that owns it (a 63 year old guy) swears that he removed it in 1970 from a 1970 Nova with a 402 with square port heads and a solid lifter cam. He also is sure that this engine/trans combination was the original that came in the car. The trans has the torque converter that mounts in six locations like the "CY" TH400 that I have used in the past. The "CY" 's came on solid lifter big block Corvettes like an L89, L88, or LS6. I'm just confused by the "CW". The guy seems like a straight shooter and definately knows his stuff on BB's as he raced many of them over the years. Has anyone had any experience with a "CW"? Thanks!
Old 04-30-2004, 07:28 AM
Default Re: Help on Turbo 400"CW"
Kevin
That is the Application for a 1970 L78 Solid lifter engine.I have this same TH400 in my Chevelle,and it was also the appication for 1970 Camaro & Nova with the L78 engine in 1970.The Torque Convertor shares the same CY trans. bolt configuration.
Look at the passenger side tag for more info on it.
The L34 Hyraulic lifter 402,used a CF coded TH400,and was different from this one.
