Old 04-28-2004, 10:36 PM
RS69 RS69 is offline
Default TH400
I've found a th400 trany and need help with some numbers. on the tag attached to the trany is the folowing: 255 stamped in the top right, then on the bottom is CQ-69-4143. Could someone plz help with these numbers. I'm trying to figure out what this trany is from. I'm told it was behind a 427 425hp motor. thanks
Old 04-29-2004, 12:09 AM
Default Re: TH400
CQ is for a 427/335HP engine,used in the Bigger Chevrolet Passenger cars for 1969.
CX was the 427/425HP engine appliction.
69 is the model year.
255 is the day of the year=roughly September 10th 1968.
4143 is that Transmissions own serial number.
Old 04-29-2004, 12:16 AM
Default Re: TH400
Thanks alot for the info.
Old 04-29-2004, 12:30 AM
Default Re: TH400
Rick,
What do you show for the CD code for a TH400?
Old 04-29-2004, 12:34 AM
Default Re: TH400
TH400 D Applications:
For 1967 & 68-327 engine,Passenger cars.
For 1969-350/250HP & 327/235HP,both passenger cars.
For 1970 & 71-400(402)/330 HP Chevelle & Monte Carlo.
Old 04-29-2004, 02:33 AM
396L35's Avatar
396L35 396L35 is offline
Default Re: TH400
Rick, What do you show for the CT code for a TH400? Thanks, Mark
Mark
Old 04-29-2004, 03:04 AM
Default Re: TH400
Mark
A 1966-68 CT TH400 code on the Passenger side tag is for series 10 & 20 Truck application.
In 1969-70 there was no CT suffix tag.The series 10 & 20 Truck became CJ.
Just to be clear,I am talking about the silk screened suffix tag on the Passenger side of the transmission.
If a Transmission shows CT on the Drivers side,with 5 non VIN# related digits after it,that is a SERVICE REPLACEMENT coded Trans.,& the same as a CE Coded Engine block was defined.
Old 04-29-2004, 03:17 AM
396L35's Avatar
Default Re: TH400
Thanks Rick
Mark
Old 04-29-2004, 03:31 AM
Default Re: TH400
Thanks Rick;
The trans I have came from a '68 Impala with a 275hp 327cid, but without a VIN on the pan rail I never knew if it was originally from that '68 Imp that I pulled it from.
