Old 03-06-2004, 03:36 AM
Belair62 Belair62 is offline
Default 70 GTO rear glass moldings
Need a nice straight set....PM me.
Old 03-06-2004, 04:42 AM
Default Re: 70 GTO rear glass moldings
Belaire
Are the 70 GTO's the same as 70 Chevelle.I am pretty sure that 66 and 67 GTO'S are the same as 66 and 67 chevelles just don't know about other models maybe someone else know's for sure and can tell us.
Bobby Dodson
Old 03-06-2004, 05:11 AM
I don't know for sure...but probably not...maybe I will get lucky
Old 03-06-2004, 06:38 AM
I know the 67 GTO will work on the 67 chevelle because that is what I used on my 67 Chevelle,The set I purchased was like new from a local Pontiac guy and he was the one that told me about 66 and 67 chevelles and 66 and 67 GTO's are the same.Hopefully someone will see the thread and maybe know for sure about the later models.If it does it may be easier to find a set.
Bobby
Old 03-09-2004, 08:25 AM
micky69396 micky69396 is offline
Hey Belair, I will check and see what I have here. If Chevelle will work I have some. I will test fit it on the Tin Indian.
Old 03-09-2004, 05:34 PM
OK but go easy with the hammer...
Old 03-09-2004, 05:58 PM
No Problem, I only have big hammers so it doesnt take much.
Old 03-09-2004, 06:03 PM
68l30's Avatar
68l30 68l30 is offline
I believe the Chevelle window is smaller.....I may have the correct trim.I'll check this week..
Steve
Old 03-09-2004, 06:05 PM
Yeah I don't think it's the same as Chevelle...that would be too easy...
Old 03-09-2004, 07:47 PM
I agree with both of you.I have found the GTO Rear window trim, different from the Malibus trim.
