Old 02-19-2004, 03:37 AM
69LM1's Avatar
69LM1 69LM1 is offline
Default 427 Aluminum Block Numbers
I am looking at buying this block, what can you guys tell from these numbers? Vette or CoPo, or either? Any help is appreciated!!!
-The casting numbers at the rear of the block are "3916321"(it has 4 bolt mains).
-The casting date is hard to make out but looks like "1 27 7".
-The stamped numbers on the front deck looks like "TI0I6TH"
-There is a partial vin on the block that reads " 18J282724"
-The crank is forged, cross-drilled and ".010/.010.
-The rods are 7/16 full floated dimple rods.
Rich
Rich Pern
Attachments - The Supercar Registry 71615-reynolds_engine_block.jpg 71592-326711_2.jpg 71591-Alum1.jpg 71590-Alum.jpg
Old 02-19-2004, 04:22 AM
jg95z28 jg95z28 is offline
Default Re: 427 Aluminum Block Numbers
3916321 = 427 cid-425hp Passenger or 400hp, 430, 435 Vette (4-bolt)
I 27 7 = Sep. 27, 1967
18J282724 => 1 =(2nd half of body style, can only be 11 2-door sedan)
18J282724 => 8 =1968
18J282724 => J = Janesville, Wi (Passenger model)
18J282724 => Passenger model begins with 100001 so that also holds true.
Now for the ??? Are you sure its TI0I6TH? That's the only one I can't find in Colvin. I found an IH for the 390 hp 427 cid passenger model with manual (1968), but the 390 HP version was only a 2-bolt block.
Jeff
Old 02-19-2004, 04:44 AM
JChlupsa JChlupsa is offline
18J282724 => 1 =(2nd half of body style, can only be 11 2-door sedan) 1 = Division- in this case Chevrolet
One of the last of that block put out also since it was stopped being used in Jan of 68. All the rest checks out.
Old 02-19-2004, 04:45 AM
Pantera Pantera is offline
How could that be a Alum block? I thought the ZL-1 blocks came out in '69?
Sounds more like a alum head L-88 motor but I was not aware that they put them in a Pass car back in 1968 according to the vin #?? That is a '68 S/N is it not?
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 02-19-2004, 09:56 PM
GMH454 GMH454 is offline
Glad you asked it. Its been puzzling me.
Old 02-20-2004, 03:51 AM
You guys are right. If those numbers are correct it is indeed a cast iron block.
Jeff
Old 02-20-2004, 04:38 AM
John Z says its a out of a 68 Caprice from the Janesville plant
Old 02-21-2004, 06:46 PM
rpoz11's Avatar
rpoz11 rpoz11 is offline
Yenko Premier Member
As far as Im aware of there are 3 BB aluminum casting numbers but I still am searching to see if there are any "0" code prototypes ever made. Im in conversations with my NCRS judge friend trying to eventually document these. RoadCourse and 1/4 mile guys to me are where I find these and occasional Marine shops Ive seen these at. Ill keep digging until Im exhausted on my searching... Also, as there were a few Small Block GM aluminum castings; Is there any Board knowledge of those #'s?
Chavez Ravine
Old 02-21-2004, 07:51 PM
KNAPPY KNAPPY is offline
What kind of numbers would an "o" block have?
Steve
67 Z-28
69 COPO Camaro
Old 02-21-2004, 07:53 PM
rpoz11's Avatar
0-123456 This would be what GM did when making Prototype pieces; This was there way of Identifying non-DOT parts manufacturing.
Chavez Ravine
