Old 02-09-2004, 01:33 AM
GMH454 GMH454 is offline
Default ZL-1 Camaro engine casting dates
Do we know what the casting dates were for the ZL-1 blocks that were factory fitted to the 1969 Camaros ???
Old 03-09-2004, 03:01 AM
Ed Cunneen Ed Cunneen is offline
Default Re: ZL-1 Camaro engine casting dates
Mostly January and February, 1969. There are a few exceptions, such as the first two cars built.
Old 03-09-2004, 04:59 AM
stingr69 stingr69 is offline
While we are on the subject, does anyone know the VIN of the other car? I have seen the VIN for one of the first 2 prototypes but what about the other one?
Old 03-09-2004, 06:24 AM
JChlupsa JChlupsa is offline
Have SEEN or was told? Big difference
Old 03-10-2004, 12:57 AM
Ed thank you, you may have seen from the few answers to a similar question in the Tech area that the casting numbers appear to be cumulative,as are the numbers stamped into blocks and caps.
The numbers stamped are lower than the casting numbers probably due to throw aways from the casting process, but still build in a cumulative fashion.
If this is correct all casting and stamped numbers would be unique.
Is this a safe assumption.
Old 03-10-2004, 02:37 AM
Jeff,
Yes, you are right. Big difference.
More to the point, I read on camaros.net a white paper that included the VIN for one of the two ZL-1 prototypes. I was hoping that someone would know the other VIN, and was willing to share the information.
-Mark.
Old 03-10-2004, 04:37 AM
x44d80 x44d80 is offline
Does this mean the first 2 cars had the early "Can-Am" type block with the provisions for a dry-sump like in the June 1969 "Car Craft" article by Bill Jenkins? The article shows him prepping the motor for stocker bashes and how it makes over 600hp on stock parts.
Old 03-10-2004, 06:15 AM
berger berger is offline
no provision for fuel pump on can am and syiamese cylinders, made the motor quite different than zl 1 motor, which was basically a alum L88, can ams like to overheat real quick cuz of cylinders and they had cast iron sleeves so they held the heat too, I read jenkins car in 67 had an alum can am, and their are tests from gm on them from that year, they would have known long before then they weren't good street motors especially in traffic, maybe just had zl 1 052 motors, they would want to test them and have emissions tests approved in advance of when production was to start I think
67 Rs modified stormer z28 482cu in.yenko camaro
67 327 camaro
69 SS 396 camaro
Old 03-10-2004, 06:57 AM
Berger please take this the right way but your last post may need some clarrifying.
The first Can Am style alloy blocks are probably VERY similar to ZL-1s, talking here of Halls Chapparal etc. We are talking VERY rare, and unclassified
The original 052s which we call ZL-1s had no water jacket between bores and the block is actually very diferrent from a cast iron L-88 block. Looks very different too. Mine has what looks like dry sump plumbing hanging off the side.The main similarity is in dimensions. 052 blocks should run liners, and should with the right cam be good street engines. Because they will run slightly cooler detonation should be helped a little.
There is also a 4.440 bore Can Am block used briefly that was also a linered block and from 356 alloy
What is usually referred to as a Can Am block, are the Reynolds blocks, that on a 3.76 stroke are around 465cubes'with 4" 495 cubes. The Green Book refers to these as 390 Alloy. (O52 blocks are by contrast 356 alloy.
These had no liners, the pistons had iron coatings. I think Jenkins had one in his 1970 Camaro.
Old 03-10-2004, 07:26 AM
they might have been the motor supplied for photos on cover of How to hotrod big block chevys by bill fisher an bob waar, its a 1971 publication all pics are black white except cover, alot of picks of jenkins motors, chapparrell, mcclaren, reynolds blocks. The motor on cover and a few shots inside has a cast number on front top of block right below intake manifold, its says 0394 150, looks like that too, with a space between 4 an 1, its large don't need a magnifying glass but it helps, intake looks like an L88 but a little different, has shot of heads top view too, this states the engine was a corvette option that also appeared in some 69 camaros, lists some part numbers and specifications such as cam, etc, cover photo credits are to ed sperko of GM photographic chevrolet public relations, intake shot says 3933163 but says its part number 3947083 open plenum different thatn 3947084 fully divided plenum both machined from same casting, also states zl1 cam is part number 3959180 stamped 9181 .560/.6000 lift duration 347 degreeintake 359 exhaust, there's even a fuel injection cam for the zl1 and canam blocks it has .6000 lift on both and 360/366 duration part number 3994094 also chain driven, gives just about every part number for zl1 motor.The real interesting article is on the 482 chevyturbo marine, 25 produced for kiekhaefer and destined for off shore long distance raceing, a few cranks, rods, and pistons were available for a short while but after a fully thorough search they were not able to find any for part numbers or pics but got specs to build one, a 454 crank stroked to 4.25 inch will provide 482 displacement w/ stock 427/454 bore, tests on one w/ two turbosuperchargers appear on pg. 125. I can give more info or publishers if any wants it, best engine book I've ever owned shows you how to build everything.
67 327 camaro
69 SS 396 camaro
