Old 02-07-2004, 12:49 AM
67rsss396 67rsss396 is offline
Default 69 396 JK engine
Ok no one with the car emailed so here it is. Block is a 395272 with date D22 and the front pad says T0423JK with the vin down by oil filter. The heads are bare and are 3931063 with date codes D21 and D22. The crank is a forged steel 6223 and i have all rods and pistons although pistons need replaced. I also have the intake 3931067 dated D22. The great thing about this engine is no front pad vin. I will trade for a 175 amp mig welder or sell for 750.00. Thanks for the AD
Old 02-07-2004, 06:44 PM
Stefano Stefano is offline
Default Re: 69 396 JK engine
So the block was stamped as a complete running assembly only one day after it was cast?
Old 02-07-2004, 06:48 PM
yountto yountto is offline
I have had several blocks in the past stamped the day after they were cast...
Old 02-07-2004, 08:53 PM
Yes the block was stamped one day after build. The deck has never been cut and the bore is a standard bore.
Old 02-08-2004, 12:37 AM
TimG TimG is offline
Sometimes, especially with small blocks, it seems like they were almost built when they were still warm. There are cases of engines cast early in the day and being built later the same day on a late shift. The casting date and build date are the same day.
Old 02-08-2004, 02:15 AM
GTO_DON GTO_DON is offline
THE BLOCK FOR THE L78 NOVA WAS BUILT THE SAME DAY IT WAS CAST
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 02-08-2004, 02:28 AM
I have two 396 next day stamped
Jake is my grandson!!
Old 02-08-2004, 04:10 AM
MosportGreen66's Avatar
That is TOO cool!
Old 02-09-2004, 05:19 PM
Almost every deuce that has contributed dates, has the casting and assy dates within 4-5 days!
Old 02-10-2004, 05:16 AM
427rcode 427rcode is offline
Default Re: 69 yenko novas
MARLIN THANKS FOR SOME OF YOUR HELP ON MY L78 NOVA DO YOU KNOW OF ANYONE THAR HAS A 69 YENKO NOVA FOR SALE .I HAVE A NOVA L78 THAT IS ALL ORIGINAL 95% ORIGINAL PAINT CAR THAT IS IN EXCELLENT CONDITION.IT IS BELIEVED TO BE A DEALER INSTALLED ALUM 427 HEAD CAR WITH THE MATCHING HEADS THAT CAME FROM THE FACTORY.I WOULD APPRECIATE ANY HELP YOU CAN PROVIDE
THANKS
RALPH
1-610-543-3300
